71 Vista Cruiser transmission
Old July 4th, 2014, 03:03 PM
lonestarjarhead's Avatar
Does anyone know which TH 400 transmission (long or short tail)was behind the 455 in a 71 Vista Cruiser? I'm using the frame under a 55 88 and want to get correct transmission to go with the frame and driveshaft,
lonestarjarhead is offline
Old July 4th, 2014, 04:19 PM
oldspackrat's Avatar
I believe there are actually 3 versions, short, med., & long, and the Vista Cruiser takes the medium length tail shaft.
oldspackrat is offline
Old July 5th, 2014, 07:08 AM
Does anyone know which TH400(short tail, etc.) is behind a factory 455 in 71 VC. Putting a 71 frame under a 55 88, and want to use the stock 71 driveshaft and crossmember, which I have, for the 455 engine. Thanks.
Old July 5th, 2014, 07:30 AM
There are/were 3 different tail shaft lengths for the TH 400, short(2 door A body cars), medium(Vista cruisers & maybe Cutlass Cruiser?) & maybe Deltas?, & long shaft(98s??). This info may or may not be 100% accurate.
I have some medium & maybe long tail shaft TH 400 cores if you need one.
Scott
Old July 6th, 2014, 09:33 AM
There are three versions, 4", 9", and 13". The 4" is what everyone calls the "short" tailhousing, used in A-body, F-body, and X-body cars. The 9" is what everyone calls "long" and was used in full size cars and I believe in the VC. The 13" is relatively rare and was used in Caddys and some full-size wagons.
joe_padavano is online now
Old July 6th, 2014, 09:44 AM
I merged your two identical threads. Typically, you'll get better info if you keep all the discussion in a single thread.
Old July 6th, 2014, 11:16 AM
LOST
twinjracing's Avatar
The two vistas I've been around both have the 9" housing just sold the core from the one I parted.
twinjracing is offline
Old July 6th, 2014, 12:08 PM
Thanks for the input guys. Looks like I can mount all the drive train in the original place and make the conversion work.
Old July 7th, 2014, 11:34 AM
Olds Wagonmaster
Arrowstorm's Avatar
I just rebuilt the transmission in my 72 Vista and it had about a 9" long shaft. Hope that helps.
Arrowstorm is offline
Old July 7th, 2014, 01:29 PM
2blu442's Avatar
Have you posted any pictures of your project yet? If not, please post some when you can.
Several decades ago I saw about a 1956 Buick on a Vista Cruiser chassis. He claimed it was a pretty easy swap. I really like the idea of keeping the vintage look but having newer drivetrain, steering and suspension.
John
2blu442 is offline
DennisG.
Vista Cruiser & Wagons
46
January 19th, 2022 01:22 PM
tcolt
February 16th, 2016 11:17 AM
tcolt
April 12th, 2015 01:36 PM
tobywoodard
December 19th, 2012 01:36 PM
70vista
December 24th, 2009 05:03 PM
Quick Reply: 71 Vista Cruiser transmission
