700r4 replacing original
Old Jul 25, 2011 | 02:27 PM
HotBoy RuNNA's Avatar
HEYYO, whats the best way of figuring how much your drive shaft needs to be shortened when installing a longer transmission. If the trans is in and u lift the drive shaft u close you cans see its too long but i don know by how muc exactly.... should i measure from the end of the transmission back to the yoke?
Old Jul 26, 2011 | 05:18 PM
jag1886's Avatar
Best way is to put the yoke in the transmission push it in all the way then pull it out 1/2-3/4 inch and then measure the length yoke to yoke, get a friend to help because you have hold both ends of the tape measure.
Old Jul 27, 2011 | 07:20 AM
Actually, pull it out about 1" to be safe. Also, be sure the rear suspension is at ride height when you measure.
Old Jul 27, 2011 | 10:01 AM
I could also use some guidance on where I can buy replacement trans fluide lines.... and a flex dipstick because it seems that the whole where the grommet sits will be well under the fire wall... this has been my first venture into working on a car of this magnitude and I have made every mistake I think you can possibly make.
Old Aug 5, 2011 | 06:43 AM
turnpike_cruiser's Avatar
When I put the 700R in my Cutlass, I called the driveline shop and asked what I needed to do. They told me to take the measurements without the driveshaft in. Call the shop you are using and ask.
I just used the Chevy dipstick tube that came with my Bowtie Overdrives 700R. It will fit, but you will need make a few minor bends.
I still had the Olds 455 installed when I installed the 700R. I was using rubber lines from the tranny to the radiator. But after installing the BBC I went with with Bowtie Overdrives stainless steel hard lines with braided stainless steel flex lines at the radiator. A much cleaner install. If I remember correctly InLine Tube makes stainless steel lines for a 700R installed in an Olds.
You can see the flex trans lines in the photo below.
Old Aug 5, 2011 | 12:15 PM
Redog's Avatar
^^ nice car
Old Aug 5, 2011 | 12:28 PM
Originally Posted by Redog
^^ nice car
TOONLOVESCHERYL
Feb 4, 2016 06:30 AM
Oldzee
Nov 16, 2014 06:03 AM
64starfire
Jun 10, 2009 06:51 AM
64starfire
Apr 22, 2009 01:00 PM
Jolly Green
Feb 25, 2009 07:25 AM
