69 350 transmission
69 350 transmission
We are thinking about swapping the Jetaway transmission in a friends 69 Cutlass with 350 engine to a either a TH 350 or 4 speed manual. Are the 350 cranks pre drilled for pilot shaft bushing? Can the same flex plate, rear mount and drive shaft be used if we go the TH 350 route? Will the same drive shaft work with the manual trans? Thanks!
esisson
May 22nd, 2008 07:47 PM
