67 cutlass 4 speed swap
Uh, any 1964-67 clutch/brake pedals should work. Hopefully you are aware of the two big problems. First, most Olds motors that came with automatics from the factory do not have the crank drilled for the pilot bearing. Second, the tab on the frame that supports the clutch equalizer shaft (z-bar) is welded on to the frame on the 1964-67 cars. Repros are available but you must weld it in place.
Big Mikey
March 27th, 2013 06:51 AM
'69CutlassVert'
August 25th, 2011 07:19 AM
Winnipeg Cutlass
April 17th, 2006 03:15 PM
