67 C/S trans
Find a local builder. You don’t need anything fancy for a 330 engine. No need to pay premium prices for a name brand high dollar builder.
Any shop worth a gallon of solvent could build a 350 trans. There just isn’t much to them. Parts are getting a little hard to find but they are out there.
Do you have a core, or could you find one? If your comfortable building and engine, a 350!is pretty easy.
Every 200,250,350,2004r,700,4L60E and most Powerglides, plus most manual transmissions all used a 27 spline shaft. The 400 and a few heavy duty 4 speed Muncie trans used a 32 spline. Are you sure your counting correctly? I don’t recall every seeing a 2wd GM trans with either of tjosev2 spline counts.
After some research I went online to JEGS and found a TH350 in my price range, the fella said the output shaft was a 30 spline.
Good thing I asked you guys and so far did not make a 1100$ mistake
Thanks for the assist
Yeah thats some kind of listing error
they show 30” spline ?
Like matt said call around find a local shop that will rebuild, they may even have a bop th350 they can rebuild for you. Then put a wanted ad on here browse cl or fbmarketplace they pop up regularly youll want a BOP bellhousing th350. Im not sure if 350s have different tail lengths but maybe some else can chime in on that. The chevy pattern th350 would need an adapter to fit your 330.
a couple weeks ago two RTR 350s were listed on here one in TN and one in CT.
jegs screen cap below shows 30” spline ?
