67 C/S 2 speed trans
The output shaft will kinda flop around, there is a case bushing that supports the front half of the output shaft. The extension housing bushing supports the driveshaft yoke, since the yoke slips over the output shaft the yoke is what technically centers the output shaft.
Slip the driveshaft yoke in the transmission, there should be very little slop. If so, the bushing is worn.
