4spd interchange
Old Apr 14, 2009 | 06:03 PM
montvaleplace's Avatar
Cool 4spd interchange
Are there any issues with putting a chevy M/20 into 442? Not taking into account matching #s things I'm just talking about mounting ears and speedo stuff.
Old Apr 14, 2009 | 08:00 PM
Cameo White's Avatar
Smile
The bellhousing bolt pattern for the blocks will be different. If you already have an Olds bellhousing you should be OK. I think, and someone else should confirm this for you, that the transmission to bellhousing bolt pattern is the same.
Old Apr 15, 2009 | 02:25 AM
Yellowstatue's Avatar
Smile Speedy
The Olds speedometer is on the passenger side and the Ch**y is on the opposite side..
Old Apr 15, 2009 | 05:19 AM
1964f-85's Avatar
if it already a 4 speed car it is a piece of cake, if it's am automatic you will need to drill out the crank for a piolet bushing. Not dificult or expensive, except you will have to remove the crank. I built a divice that bolts to be bell housing and centers a drill bit into the end of the crank, but unless you know a competent fabricator to make fit prfectly, I wouldn't recommend it.
Old Apr 15, 2009 | 06:56 AM
Cool
I already have the correct bell housing, my question was to the tranny mounting ears and speedo arangement. It sounds like it's not a big deal either way--Thanks...Tony...
Old Apr 15, 2009 | 03:06 PM
jensenracing77's Avatar
in that case, yes it will bolt right in. you will have a little extra speedo cable. you should be able to loop it over the transmission case. the M 20 has a lower first gear in it. makes good launches.
toms455cutlass
May 25, 2008 08:13 PM
The_Jeremiah
Drivetrain/Differentials
Jan 27, 2008 12:18 AM
Oldsmaniac
Jan 16, 2006 05:55 AM
