47 Coupe New to the site.
Old Feb 29, 2008 | 01:50 AM
47 Coupe's Avatar
Hello all. This looked to be the best place to learn more about the Early Rockets. I recently obtained a 47 Olds coupe, Flathead 6 single barrel carb and Hydramatic drive. I'm in need of some experience of the Hydramatic drive transmission. The car upshifts seems ok. Goes into final 4th gear quickly compared to other automatic drives, but ok, its the downshift that seem to hang in there. Will stall out the engine before shifting into first. I'm going to rebuild the carb to see if that will give the engine more power to over come the shifting. Is this a norm or what does experience have to offer? I would appreciate any and all thoughts. Thanks
Old Feb 29, 2008 | 07:48 AM
Oldsguy's Avatar
Past Administrator
Welcome to our site. If you need any parts I have the engine/transmission that came out of my '46. I will check my service manual information to see if there is an adjustment on that. Good luck.
Old Feb 29, 2008 | 04:45 PM
ozoneblue's Avatar
Welcome to the site ,Sorry my transmission skills are limited to fluid filter & flush.Or I try to help. larry@vintageozarks.com
Old Mar 1, 2008 | 10:39 AM
88 coupe's Avatar
Junior Member
Originally Posted by 47 Coupe
........ Goes into final 4th gear quickly ........ ........ Will stall out the engine before shifting into first ........
Sticking governor is a good possibility. Easy to access by removing the side cover. Most trans shops can get the gaskets, seals, etc, for you.
'49 trans is pretty much the same as yours, Download the pages you need from tocmp.com.
........ I'm going to rebuild the carb to see if that will give the engine more power to over come the shifting .........
Don't fix what ain't broke.
Norm
fiona72
Aug 31, 2013 11:32 AM
kruss77
Aug 21, 2009 07:35 AM
Steeb
Feb 18, 2009 02:01 PM
Brizio
Feb 15, 2009 07:07 PM
southcarolina803
Jun 28, 2008 07:33 PM
