455 to 425 th400 swap?
Old Mar 27, 2007 | 08:08 AM
delta88NC's Avatar
i found a great deal on a th400 that was pulled from a mid 70's 455 olds. was wondering if it will bolt up to my 425 1967 delta 88 with th400?
Old Mar 27, 2007 | 08:23 AM
Oldsmaniac's Avatar
It will bolt but the flywheel bolt pattern is different so you need to use the 425 flywheel. The 67 also used the switch pitch and the later is not. This should not be a problem.
Old Mar 27, 2007 | 12:27 PM
frdmftr's Avatar
Freedom Fighter
Switch pitch?
Old Mar 27, 2007 | 01:12 PM
Oldsmaniac's Avatar
The switch pitch was a type of early lock-up torque converter and trans. Olds used it on the turbo 400 from 65 to 67. On the throttle linkage under the hood near firewall there is a switch mechanism that controls the switch pitch and also kickdown for passing gear I believe. The factory shop manual has info about the switch pitch.....maybe others can elaborate on this.
Old Mar 27, 2007 | 03:53 PM
frdmftr's Avatar
Freedom Fighter
Everyday I learn something new about the 'Olds' world. Being a traditional 'bowtie' guy from birth, I was sheltered from this wonderful invention.
I also was smart and bought a factory service manual for 67 Olds. Here is the information from that publication:
"The stator control solenoid is activated from a switch in the throttle linkage at engine idle which changes the stator blade angle (pitch)from low to high. It is also energized at 40 degrees and over of carburator opening by a switch in the throttle linkage to change the stator blades from low angle to high angle."
Hope this helps others, it did me.
Dave
rpinnt
May 31, 2015 08:34 PM
Dogman691
Mar 12, 2013 08:32 PM
70cutman
May 22, 2011 09:03 AM
TRW
Jan 21, 2011 05:38 AM
ls442
Nov 11, 2010 10:45 PM
