400 turbo won't kick down
We installed a 400 turbo in a 67 442. We have 12 volts to the transmission when the gas pedal is floored but it won't down shift when driving the car. We tested the ohms on the kickdown terminal on the 400 tranny and it has continuity.
Any ideas?
Any ideas?
Are you still running the factory transmission control switch? Just making sure you have it connected to the downshift solenoid terminals and not the converter switch...
Assuming it was a Jetaway car and the Jetaway downshift was working before?
This is aggravating, but try wiring up a temporary switch. Wire it up to 12v, thru the switch and to the solenoid connector. Have a helper operate this switch by hand when you road test and see if it will downshift with this switch. If it does, you know the trans is working and it's a switch or adjustment issue. If not, it has to be the detent solenoid in the trans case or something else internal.
I read up on the 67 kickdown device and it does have 3 terminals. We are using the terminals that make contact when the pedal is on the floor. I am 100 percent sure it has 12v to the transmission solenoid when the gas pedal is on the floor. We checked it twice. I'm not sure what I would gain by rigging up a hand held switch but I know cars pretty well and weird things happen so we'll give it a go to confirm a problem. If it fails to kickdown, it looks like a problem with the solenoid.
You can usually hear the transmission solenoid 'click' if you listen closely with the key on, engine off and pedal (or pedal switch) depressed. TH400 transmission solenoid failures are really common. I think I had to replace the trans downshift solenoid in every TH400 I've had at some point or another.
I have a 69 442 with 400 engine and th400 trans. I found my transmission downshift switch unplugged at the gas petal. My assembly manual has a note "on cars with 35M38, tape downshift leads and connector back on main wiring harness with (specified) tape".
What does 35M38 mean? I am thinking that maybe the downshift switch was not connected because there is no electric solenoid connected to it.
Anyone know what is going on?
The solenoid is very easy to replace once you drop the pan. Disconnect the wire from the plug on the trans case and remove one bolt and the solenoid comes off. I assume this trans that you added is NOT a switch pitch. The switch pitch transmissions use a second identical solenoid for the converter stator pitch control. Regular TH400s only use the one solenoid.
The Switch Pitch is also activated at WOT so it will show continuity also. Does the trans have a two prong plug or a one prong? The bottom one should be the downshift on a two prong.
I have a picture of the throttle assembly. Terminal 2 is the downshift connection
Thanks, Joe. I think I will unplug the kickdown switch and leave it unplugged. I don't plan to be floor-boarding the accelerator on a 44 year old car any time soon. If I need to downshift, I can take my right hand and move the gear shift lever from D to S whenever I feel the urge.
oldspackrat
Mar 30, 2013 04:57 AM
