2004r finished!!
Old Jul 18, 2020 | 10:05 PM
big man's Avatar
2004r finished!!
Well with the help from the knowledgeable guys here and CK's manual I have officially been able to rebuild my first trans. It shifts absolutely great and feels responsive.
I've replaced transmissions and done my valve body but I have yet, until now done the hard parts. It was interesting to say the least.
I thank all those who chimed in to help with questions that I couldn't figure out. Hopefully other guys here who are rebuilding their trans will fix it with precision. Thanks again..now next up is some body work
Old Jul 20, 2020 | 05:54 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Awesome, I am planning on the same thing with the 2004R to live behind healthy torque. Glad it works as it should.
Old Jul 20, 2020 | 06:17 AM
big man's Avatar
Yea it just feels 'stout' and I don't mind chirping the tires on shifts either lol, thanks.
Old Jul 20, 2020 | 07:10 AM
RetroRanger's Avatar
72 Olds CS
I would like to build a trans someday. Good on you for getting it done!
Old Jul 20, 2020 | 12:18 PM
big man's Avatar
Thanks. It wasn't too bad with the book and using the guys here who know their sh*t.. That's what helps.
Old Jul 26, 2020 | 06:31 AM
adis's Avatar
'72 Supreme vert (Mango)
Congrats on the build! Curious what fill tube/dipstick you used?
Old Jul 26, 2020 | 06:52 AM
ELY442's Avatar
What tools did you use? Anything special or you use just a basic hand tools?
Old Jul 26, 2020 | 07:35 AM
big man's Avatar
I used the dipstick that the 2004r came with. I did overfill the trans about a quart for the road test. Best reading is when the pan is off and seeing how far the dipstick reaches into it
Holdings fixture for the case, dial indicator, feeler gauges, adjustable stand for the low reverse setup (forgot the name of it) shift kit of your choice, vise grips and tape for direct & forward drum, what they call the 'abortion tool' for getting out and putting in the center support..if I think of anything else I'll chime back in. Tools can be found if you check your trans shops or look on ebay, online etc..
442craig
Apr 13, 2021 07:52 PM
70CCV
Jan 17, 2015 07:44 PM
Big Leche
Feb 3, 2014 01:15 PM
coppercutlass
Aug 4, 2013 07:21 PM
Olds5798
40
Sep 23, 2012 08:04 PM
