1969 Cutlass flat top wagon with TH400
Old Jul 28, 2017 | 03:26 PM
bardcutlass's Avatar
My 1969 Cutlass flat top wagon has Rocket 350 2bbl with a TH400, the numbers all match.
I thought the Rocket 350 came with the TH350????
Old Jul 28, 2017 | 08:36 PM
svnt442's Avatar
It was common for the wagon to the the TH400. It also might have a tow package on it and that would for sure get the TH400.
Old Jul 29, 2017 | 06:55 AM
No, it really wasn't, at least not on the flattop wagons. VC's got the TH375, which is a low-rent TH400 with the smaller TH350 output shaft and light duty internals. Here's the 1969 SPECS booklet page that lists the trans options for the Cutlass wagons:
To the OP: What numbers "match"? You've verified that the VIN derivative on the trans case matches the VIN of the car? What's the two letter tag on the trans case?
Old Aug 1, 2017 | 09:01 AM
Yellow tag reads:
OD-69-6025
engine number:
39M192477
Trans number:
39M192477
Vin:
336359M192477
The output shaft is the same diameter as the other two th400's I have.
Old Aug 3, 2017 | 01:45 PM
So....would this have been a special order?
Giftman23
Apr 14, 2012 08:46 PM
Homestar
Apr 12, 2012 12:10 PM
vistacruiser1971
Feb 1, 2012 04:48 AM
scot w.
Aug 18, 2009 09:03 AM
Phil
Aug 14, 2009 12:33 PM
