1968 Hurst/Olds OW VS. OG 442 transmission
I just removed the transmission from the '68 H/O, the original owner told me he cracked the original case and put the "guts" in another case (a '68 "OG" case)
what internally would be different? any special components from the "OW" transmission that can be ID'd?
The trans from my 69 H/O had an extra friction and steel in the direct clutch pack. The direct clutch housing was different as a result.
