1967 Toro Transmission HELP!
When I do a hard acceleration (mash the gas pedal to the floor) my transmission will not down shift. Any ideas other than taking it to a transmission shop?
Thanks,
Tom Severski
832-594-9541
Thanks,
Tom Severski
832-594-9541
Just had the carb rebuilt - they told me transmission was not downshifting (I already knew that) and offered to diagnose the probem for $500. Since they just rebuilt the carb, I hope that is not the problem!
$500 is steep. Could be something as simple as a vacuum leak. Or could be the transmission and everything in between. Friend has a 75 Eldorado that did not downshift. He was missing a part next to the carb. Dont know what it was, but cost him $20 in the end
Thanks for the information. I thought $500 was way high to just diagnose the problem, espically after I just paid them $600 to rebuild the carb! Think it might be time to find a new mechanic!
By the way, this is about a 30 minute diagnostic job, so your oh-so-helpful carb shop is making $1,000 an hour. Find a new mechanic...
Carb rebuilding serivice is around $300 - $400
Can get it all over the web
http://www.thecarburetorstore.com/servlet/Detail?no=28
http://www.quadrajetcarburetors.com/...g-service.html
I'm not sure how this relates to fixing the trans, but if you are referring to my $1,000 an hour comment, that's based on the quote of $500 to diagnose the downshift problem, which should take 30 minutes. Do the math. It's unrelated to carb rebuilding.
Joe,
Thanks for the advise.
Concerning the carb work, the guy has a good reputation, and he did the removal, replacement, and adjustments. No real complaints about the carb! Just trying to get the tranny to down shift!
Thanks,
Tom
Thanks,
Tom
jensenracing77
November 15th, 2009 03:11 PM
