1965 Cutlass - Need to replace shifter, but keep console
Old Mar 21, 2017 | 11:22 AM
65CutlassClint's Avatar
I have a 65 Cutlass F85 w/ TH350 transmission. The original shifter needs replacing. I would like to keep the original shifter console with the tach on it...any suggestions on replacing the shifter? I purchased a Hurst Quarter Stick (being shipped) but I am concerned that the reverse lock mechanism will prevent me from using it with the original console.
Old Mar 21, 2017 | 04:24 PM
lemoldsnut's Avatar
I have used a 67up shifter in those consoles before and it worked nice.
Old Mar 22, 2017 | 07:49 AM
I assume the original shifter lever is broken (as usual), which is why it needs to be replaced. If you just need to be able to use it with a three speed AT, you can get a conversion kit from Shiftworks.
If the shifter is broken, the G-body shifter has been used in the 64-66 console as a replacement.
Old Mar 22, 2017 | 03:42 PM
Yes, the shifter is broken. I was hoping to be able to buy something like a Hurst or B&M from Summit or Jegs that someone else has had success using in the past with a stock 65 cutlass console w/ factory tach...I do not want to cut it up if I don't have to.
Old Mar 22, 2017 | 03:54 PM
Donolds's Avatar
Check with Shiftworks in Vegas. I converted to floor shifter when I had an Art Carr overdrive installed. Art ordered a shifter from Shiftworks that has a 3/8's shaft and a choice of black or white shift ball. It works and looks great.
No cutting involved.
Old Jun 21, 2017 | 01:22 AM
Seabass152's Avatar
Quarter stick fits well but you have to make a small relief for the reverse lockout lever. Not a great pic but for reference
BeenThere
Jun 27, 2015 12:04 PM
marxjunk
Jun 12, 2014 12:34 PM
gearheads78
Jun 7, 2012 11:02 PM
Rickman48
Dec 3, 2011 04:35 PM
