1963 F 85 Trans. Question
Old May 22, 2016 | 07:06 AM
67Rocket's Avatar
A friend of mine has a 63 F85 with a 3 speed on the column manual trans. What issues will we run into if we try to install a Saginaw 4 speed trans. from a mid seventies Buick Skylark into his car? The car has the original 215 engine it. Thanks for any help and suggestions.
Old May 22, 2016 | 07:36 AM
The 63 SHOULD have the bellhousing that has both trans bolt patterns (the original three speed uses a unique trans-to-bellhousing pattern that's different from the normal GM Muncie/Saginaw pattern). The factory four speed was a T10, and I believe it had a shorter tailhousing than those on later T10s. The space in the tunnel is very limited on these cars and the Saginaw may not fit without metal work. Driveshaft mods will also be required and I suspect the crossmember will have to be relocated.
Old May 22, 2016 | 09:25 AM
Ancient Iron's Avatar
Driveshaft also has to be changed ,Due to having a companion flange on the transmission and the slip joint is in the middle of the shaft. Also a single piece shaft might not clear the driveshaft tunnel.
Old May 22, 2016 | 01:07 PM
67Rocket's Avatar
We appreciate the information.
trackz man
Aug 29, 2016 04:32 PM
barbiekiddo
May 23, 2014 08:45 PM
barbiekiddo
Feb 16, 2014 07:18 PM
convertible 63
Jan 24, 2011 02:40 PM
1k442
Mar 3, 2010 08:03 AM
