1941 hydramatic
Old Jan 9, 2015 | 02:45 PM
Robert Kiedrowski's Avatar
rkiddo41olds
1941 hydramatic
I have a 41 Olds hydramatic and the converter leaks back into the main transmission housing after it sits for a day or so. I know it leaks back because the dip stick is about 3" over the full mark. I have to wait about 4 or 5 seconds before the car will move. Does anyone know of a check valve that supposed to keep the converter full and if so where is it located.
Old Jan 23, 2015 | 10:53 AM
d2_willys's Avatar
I believe the check valve is in the fluid coupling. Look at the diagrams and you will see a spring loaded cup like thing. That is what I believe is the check valve. Perhaps it was installed backwards.
Robert Kiedrowski
Jul 1, 2013 02:00 PM
Robert Kiedrowski
Jun 19, 2011 09:20 AM
Robert Kiedrowski
Oct 10, 2009 10:36 PM
daves62
Dec 20, 2008 04:21 PM
skip
Oct 11, 2008 08:19 AM
