Parts interchange for 69/70 Toro
I know that the front was changed quite a bit between 1969 and 1970 for the toro, but the rear ends look mostly unchanged. does anyone know if the trunk lid , bumper, or tailights from a '70 will fit right in a '69? and if anything will interchange fine?
They'll bolt right up but the taillight lenses are different. 70 also has its rear marker lights in the bumper instead of 1/4 panel as 68-9 do. A 1968 rear bumper will work but will require drilling mounting holes to use 69 taillights.
Thank you for the info! I just want to make sure i dont buy the wrong stuff when it comes time to get these parts. this helps alot!
