1979 Toronado Brougham (Red)
Old Nov 26, 2019 | 04:26 PM
lawsrolf's Avatar
350 V8,4 Barrel Rochester Gas All Electric 83k miles
https://classicoldsmobile.com/g/album/15960985
Repairs and upgrades:1979 Oldsmobile Toronado Brougham
1979 Oldsmobile Toronado Brougham Coupe, 83K plus actual miles with DMV History, 350 Cid gas, V8, All electric, AMFM Radio Cassette Serviced, Remote Mirrors, Individual electric adjustable Bucket Seats, All Power, All numbers matching. No rust, no body damage, no accidents.Production 795, New Jersey and sold on West Coast to Washington and then to Las Vegas, NV. Clean Title
1.New gaskets for oil pan, transmission pan, differential, valve covers
2.New rockers, push rods and bridges
3.New Directional signal switch
4.New Universal Power Antenna
5.Car Cover
6.New Steering Wheel Cover
7.New Trunk & Hood Lift shocks
8.New hood liner
9.New body mounts (frame to body)
10.New Brake Master Cylinder
11.New Coil Springs & Front & Rear Shocks
12.New Motor mounts & Transmission Mounts
13.Wire Hub Caps & plain hub caps included
14.Alignment
15.New Tires, 60,000 mile warranty with 600 miles used
16.New CV Axles, inner outer tie rod ends, ball joints & Hubs
17.New rebuilt steering gear box and all connections
18.New Front Stereo Speakers, AMFM Cassette serviced
19.Newly rebuilt Rochester Quadrajet 4 barrel carburetor
20.New Trunk lock
21.New battery
22.New Fiber Glass Front & Rear Bumper fillers
23.Steering Column overhauled up to the steering gear box
24.New Wiper Motor & Washer
25.New Door lock relay
26.New Door Lock Actuators (both doors)
27.New Paint to original Carmine Red color
28.New Upholstery & Headliner
29.New Complete brake parts, rotors, springs, calipers, wheel cylinders etc.
30.All fluids flushed and re-serviced, water, radiator, differential, transmission, oil, brake fluid.
31.New RadiatorR134 AC, new compressor, dryer unit, orifice tube, flushed evap & condenser.
32.New Thermostat, all hoses replaced
33.New oil sending unit and water temperature sensor
34.New oil pump, transmission filter, fuel pump, fuel filter, fuel sending unit, alternator, ignition control module, distributor power pack, PCV valve and EGR valve
35.New plugs and wires
36.New Low and High Beam Headlights
37.New light switch
38.New window weather stripping both sides
39.New fuses (all)
40.New Upper Control Arm Bushings both sides.
41.New Catalytic Converter
42.Newly rebuilt transmission per previous owner, No rust or body damage to frame or anywhere. Garage kept all these years. 3rd owner
lawsrolf
Nov 27, 2019 02:03 AM
CustomCruiser1979
Jan 11, 2016 02:48 PM
Coronado
Jan 30, 2012 10:36 AM
dlinderm
Aug 16, 2011 09:12 AM
HouTXCutlass
Nov 1, 2010 06:30 AM
