In Need of Toronado Exhaust Flanges
Bought a new exhaust for the Toro. It didn't come with the flanges that slip over the pipe and bolt to the Manifold. Anybody got a pair? Can't find any on the interweb either. also in need of the springs that go on the outboard edge of the drum brakes. Mine are just plain shot.
http://www.inlinetube.com/#!product/...ges---inl11139
Will these work? Opinions? They are the correct pipe size but will the bolt holes line up?
I got them from Rockauto. A Ford application. Really just a question of the pipe OD and the hole spacing on the exhaust bolts.
The original ones were shaped / stamped sheet metal, the Rockauto Ford ones were a slab of billet iron.
I almost took it for a ride tonight. Would have been the first time I drove it after owning it for 3 years! I drove it out of the warehouse and pulled the lights. No go. Vacuum issue. I'll sort it out tomorrow. I did bleed the brakes and filled the power steering pump. No leaks whatsoever. Liking that a lot! Still have to figure out why the wipers aren't working. Easy stuff now. Thanks for your help. Car needs a bath bad. The guy who had it in his shop for the last three years painted a truck while my ride was there on a rack. Reddish dust in every crevice. Yeesh.
QuinnKnight
November 7th, 2019 05:19 PM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
