Sensor on Left intake manifold
Old May 29, 2024 | 04:33 PM
Ty Chamberlain's Avatar
I have a 1966 that I am finishing. It has a sender on the left side intake manifold instead of a manifold bolt. Any ideas?
Old May 29, 2024 | 04:51 PM
A picture would assist immeasurably.
Old May 29, 2024 | 05:27 PM
I know, I will take one in the morning
Old May 29, 2024 | 05:57 PM
2blu442's Avatar
Is it on a Toronado?
Old May 29, 2024 | 06:03 PM
Yes 1966 Deluxe
Old May 29, 2024 | 06:43 PM
2blu442's Avatar
I've got some Toronado engines and parts cars and have seen that before. I'm thinking its a temperature sending unit. I'll see if I can find anything out that will help you find the wire for this. John
Old May 29, 2024 | 07:07 PM
rocketraider's Avatar
Oldsdruid
"Stop engine" warning lamp sensor.
1st generation Toronado tended to run hot. If owner didn't pay attention to his temp gage or "hot" warning lamp, and the cylinder head temp got high, this sensor triggered a flashing "STOP ENGINE" warning.
There is a head bolt in that position. The sensor threads into it.
Old May 29, 2024 | 07:13 PM
ourkid2000's Avatar
Rocketraider, was this something that was available as an option on the '66 or something? I feel like I remember reading that this was something that came later, maybe on the 455 Toronados?
Old May 29, 2024 | 07:14 PM
The internet is incredible. Now to find the wire
Old May 29, 2024 | 07:35 PM
2blu442's Avatar
What I had in mind is actually a head bolt with a wire plug attached to it. Is this what you have, or is it something different? Here's a couple pictures of newer ones. The one with a green wire, the same color as the sensor that goes into the pass front intake mainifold is a 1968. The bolt without a wire is in a 1969.
Old May 29, 2024 | 07:44 PM
That is it!! Now to find the wire.
Old May 29, 2024 | 07:46 PM
2blu442's Avatar
Do you have a Chassis Service Manual? That would have a colored wiring schematic showing where the wire goes. On the 1968 it runs around the front of the intake manifold and joins a wiring harness at the front passenger side of the intake/valve cover.
Old Jun 15, 2024 | 12:20 PM
Oldsdruid
I had to unearth the 66 CSM to answer a question about ignition switch lock cylinder removal and remembered this thread.
I can't find the stop engine sensor wire on the 66 E-car wiring diagram. Those and 67 had temperature gauges so probably didn't have the warning lamp. Here's a 68 cluster showing the two TEMPERATURE warning lamps. HOT lamp (right side of pod) is steady red, STOP ENGINE (left side) is a flashing yellow.
Ty, is there a possibility your car has had a later 455 engine or maybe cylinder heads installed sometime in the last 58 years? 1966 should have B heads. 67-69 had C and 1970 were E. I don't think you'll find the temp sensor wire on a 1966.
griffey57
Feb 27, 2024 03:44 PM
dcmd21
May 2, 2023 03:51 PM
Sep 15, 2019 04:30 PM
Mytime
Aug 4, 2018 09:10 PM
Skitch72
Jun 18, 2014 09:35 AM
