Rusted out Drainage box
Old May 12, 2013 | 12:25 PM
SJL's Avatar
SJL
I have realized I have a major issue. in the long term storage of the Toro the drain box at the base of the windshield is rusted out over top of the fuse box! I found the problem with my electricals and need to know if there is anyone who has had to fix this.
It rained yesterday and I realized the floor was wet from the drive to a car show. So now I have the source of 2 of the issues with this car.
Any help in a process to fix this would be appreciated.
Old May 18, 2013 | 01:19 PM
bluecab's Avatar
Mostly Gristle
Drainage box repair
Depending on how much of the car you have apart, or want to take apart, welding a new piece of metal in would be the best or most correct way to fix this.
That being said, it could also be effectively patched with fiberglass cloth and epoxy or fiberglass resin without taking as much of the dash apart.
I have the same issue on my '66 and have not yet decided how to fix it.
Check the rear drainage box too as these had hoses that clogged with leaves and the lower hoses were prone to rot which let the trunk drops fill with water.
Good luck!
David
Old May 18, 2013 | 02:35 PM
SJL's Avatar
SJL
Thanks (I think) for the info. I seem to have both front and back drain issues. The trunk has some wetness as well. I think I'm taking it to the body shop and have them deal with it. I want to do it in metal so it looks factory. Can anyone send me pictures of a 1970 that is in good shapes for a pattern.
Old May 18, 2013 | 03:41 PM
Octania's Avatar
Unless this is a 1 of 1 factory experimental Hurst Toronado, I think you are being too meticulous in seeking to make it indistinguishable from factory. Just fix it with metal if possible or fiberglass if welding is too much hassle... and call it good.
jrainwater73
Body work
Apr 27, 2015 11:41 AM
SJL
Body work
May 14, 2013 04:20 AM
GrammasPride
Drivetrain/Differentials
Sep 4, 2007 10:14 PM
SuperSickBoy
Oct 3, 2006 12:51 PM
johndep
May 11, 2006 06:22 AM
