Repair of fuel gauge ( not showing correct amount )
The gauge doesn't accurately show ( doesn't work-stuck at 3/4 or so full ) how much fuel is in the car. What do I need to fix/replace to get operating correctly?
Thanks.
Thanks.
fuel tank sending unit
I never found out what year your car was however buick riviera, eldorado and Toro had the same unit. I found mine on ebay but had to cross reference the numbers from GM until I hit on the right one. Just make sure of the number of connections to the sender unit meaning the number of hoses that connect to it. Mine has emission return line with fuel return and output. Good luck, hope this helps ya.
So far I see two and am unclear if either or both, for that matter, work for a '70 Toronado.
TIA
https://jcaparts.com/products/1967-1...k-sending-unit
https://www.carparts.com/details/Uni...t/A483262.html
TIA
sorry...1970
I would go with the Jcaparts.com cause the Toro is considered a full size just like the others, however see what you can find regarding the Riviera and Eldorado and see if they come up the same.
![](https://cimg6.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/1920x1080/69_toro_in_mcclare_driveway_0c6d42b6112b700058d55056078bc130b35abe62.jpg)
![](https://cimg0.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/1600x1200/1_190724_toronado_fuel_sending_unit_canister_housing_reconstructed__0ce9b1c9733c266674e1b995ff701990923a9a9b.jpg)
Cannister style sender unit
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1695/190730_69_toronado_fuel_sending_unit_no_dbl_contact_float__e29d84f5126263ba616be435aea1f265f3f1ab10.jpg)
float and contact component
