Rattles in the front end, 87-92 toronados
Old Apr 9, 2015 | 03:27 PM
Hurk's Avatar
Anyone knows why all the rattles that come from the front end of the e frame toronados 86-92 i cant get read of? event after replacing the struts & ball joints the rattles are still there. any ideas would be greatly valued.
Old Apr 22, 2015 | 03:56 PM
DJS70cutlass's Avatar
Sway bar links and radius arm bushings (also called strut rod bushings) would be the first things I'd check.
Old Apr 22, 2015 | 04:36 PM
Hurk's Avatar
Thanks i will check that.
Old Apr 23, 2015 | 03:51 PM
illumined's Avatar
1978 Ninety Eight
Check the rest of the bushings in the front end too, as well as look for any loose bolts. I once had a loose bolt in the transmission that was doing it. Also keep in mind that bushings can look good but still be starting to go bad. Do you also have any vibration as well?
Old Apr 25, 2015 | 05:10 AM
Hurk's Avatar
No vibrations, I should remove the lower control arms and check the bushings. thanks for the tip.
Old Apr 26, 2015 | 07:22 PM
illumined's Avatar
1978 Ninety Eight
If it was a bushing you'd have excess vibration from the engine on idle and/or sometimes the road depending on which kind have the problem. The linkages DJS referred to, one or more loose bolts somewhere, or perhaps a bearing in something that's starting to fail could do it too (I had a dying water pump that did this), those are your best bets at this point. I wouldn't suggest throwing parts at it unless there's something that's clearly starting to wear out, there's an awful lot of things that can cause it.
Old Apr 27, 2015 | 08:20 AM
wcourt3010's Avatar
did it squeak before you did the work? my car used to squeak, moan etc. driving and i replaced the rubber bumpers that go between the hood and the fenders, put four on each side. squeaks went away.
Old Apr 27, 2015 | 04:20 PM
Hurk's Avatar
Yeah it squeak before the new struts. I have to check for loose bolts on the lower control arm that would do it too but you know what i replaced the strut rod bushings now its all good thanks everyone for the help.
Old Apr 30, 2015 | 08:59 PM
milesmonte's Avatar
It's the STRUT MOUNTS
Old May 1, 2015 | 03:21 PM
When I'm right I'm right.........those bushings always get neglected on those chassis. Glad you got it fixed
Old May 26, 2015 | 10:20 AM
Hurk's Avatar
Bingo yes it was the strut mounts. just so everyone knows.
Old May 26, 2015 | 03:16 PM
milesmonte's Avatar
When I'm right I'm right!!!!!!!!
Old May 26, 2015 | 03:18 PM
milesmonte's Avatar
You should alway's replace your front strut mounts when replacing your front struts!!!
mark77301
Oct 26, 2019 06:23 PM
67Olds442X2
Mar 2, 2010 08:27 PM
jmiles13
Apr 11, 2009 06:35 AM
sportynut
Jun 13, 2007 09:06 PM
80nadorider
Feb 22, 2007 07:55 PM
