Parting out 1969 Toronado
Old Mar 2, 2013 | 06:18 AM
wikkonado's Avatar
Straight body, minor surface rust, sat in a barn for ~20yrs.
All glass intact.
Running/driving car, but needs far too much work (entire floorpan full of holes, etc). to keep.
Might wait until spring for the bigger things, but thought I'd get a head start on some of the smaller things if I have them.
Will provide pictures of specific things if requested.
Old Mar 2, 2013 | 01:32 PM
grindlecrew's Avatar
69 toronado
does the car have front disk brakes? if so would you sell 2 or 3 of the rims?
Old Mar 3, 2013 | 02:44 AM
EightballZ's Avatar
what about the steering wheel? condition? color?
Old Mar 3, 2013 | 12:56 PM
wikkonado's Avatar
It does have disk brakes.
Although they would probably be the last things I'd sell, as I still need to move it around now & then, and don't have anything else to put on it.
It's the same as the one in this picture, but green:
http://forums.aaca.org/attachments/f...1-dcp_1340.jpg
The outer wheel itself is not good, cracked, small pieces missing.
The horn pad is good.
Old Mar 4, 2013 | 08:21 AM
sdcarguy's Avatar
turn bezel
I need a turn/cornering light bezel/assembly for the left side. It isn't in the grill. it's in the fender. It is a combination turn signal (amber?) and turning/cornering light (clear). sdcarguy
Old Mar 4, 2013 | 09:01 AM
orange442's Avatar
If you have or can get some Chevy 1/2 ton 5 lug wheels they will bolt right on. That is what I have on my Toro right now. Sold the wheels to a guy on this site from Sweden.
Old Mar 4, 2013 | 11:22 AM
wikkonado's Avatar
I found the wiring harness, but not the bezels or housings. I might not even have gotten them with the car.
(Everything was off the car when I got it, previous owner was going to prep it for paint before he abandoned it)
Old Mar 5, 2013 | 07:16 AM
dzazzehr's Avatar
mirror
Do you have the drivers side mirror, and which one is it?
All glass intact.
Old Mar 7, 2013 | 12:29 AM
wikkonado's Avatar
I can't find them at this time. The garage is pretty packed in for winter, storing other things and all.
I'll keep looking when I get time.
Old Mar 12, 2013 | 04:23 PM
sdcarguy's Avatar
The front bezel I need is pretty easy to spot. If the hole in the fender is around 16 inches long, I'll wait for the spring thaw. If it's only about 7 inches. you don't have one. Thanks for your help.
Old Mar 28, 2013 | 05:53 PM
Rob Andre' Stevens's Avatar
Need the chrome moldings that go around the passenger side wheel wells front and back, do you have 'em?
Old Mar 28, 2013 | 07:46 PM
rocketraider's Avatar
Oldsdruid
I'm not following this at all. 68-69 Toronado cornering lamps are incorporated into the side marker section of the parking lamp assemblies- the bumper wraparound section. You'll find both the side marker and cornering lamp sockets in the wraparound section. It is not in the fender at all; if you have such someone has put a 1970 marker and cornering lamp on your car.
Believe me, I've had the ones on my 69 apart enough to know. I had to take them apart and rebuild them due to bad springs and socket corrosion.
Old Mar 29, 2013 | 11:08 AM
sdcarguy's Avatar
Smile
Well, thank you for that information. I was under the impression that the 69 and 70 were the same. No wonder I haven't been able to locate one. I'll leave this guy alone and go bother someone new.
Old Apr 2, 2013 | 08:37 PM
deaddds's Avatar
SD drop me a line at dead@mchsi.com I believe you have the combo marker/cornering light. I'll take a pic of the pair that I have and make sure thats the part you need. Regards Pat
Old Apr 3, 2013 | 11:18 AM
dnmfranco's Avatar
pm
pm sent
Old Apr 9, 2013 | 11:21 AM
wikkonado's Avatar
Yes, do you know how long they are exactly?
I have all the chrome bundled together, unsure what is what.
Old Apr 13, 2013 | 06:48 PM
CJC's Avatar
CJC
Would you have the courtesy light lenses above rear back seat, the trunk light that mounts on the inside of the trunk, the dash gauges? Thanks, Jim
Old Apr 14, 2013 | 07:12 PM
CJC's Avatar
CJC
Did you receive my E-Mail which shows up under your ad? Thanks, Jim
Old Apr 14, 2013 | 07:36 PM
wikkonado's Avatar
1. No courtesy lens.
2. No trunk light.
3. I have two sets of dash gauges!
They both look nice, nothing broken.
(Cluster 1, still in car)
(Second cluster)
Old Apr 15, 2013 | 05:40 PM
CJC's Avatar
CJC
Great- could i telephone you? I am a new member and not sure of the protocols. If I am not breaking the rules could you reply to me at cumming2@telus.net. regards
Old May 1, 2013 | 10:59 PM
oldsrocket88's Avatar
Can you get into the trunk? I am looking for the small zig zag shaped bracket for the jack hold-down. It should be on the drivers side of the trunk and is held down by a wing nut.
Old May 4, 2013 | 07:22 PM
SJL's Avatar
SJL
Does it have the hubcaps? I could use all 4. I also need the door switches for the power locks and windows. I need the plug for the drivers side door lock as well.
Any of these would be appreciated.
Old May 20, 2013 | 11:55 AM
wikkonado's Avatar
No bracket or jack in the trunk, sorry!
Old May 20, 2013 | 12:07 PM
wikkonado's Avatar
Got all 4, very nice condition under all that dust.
I believe this is what you were asking for?
This harness?
Old May 31, 2013 | 09:51 AM
Dirtyoldsman's Avatar
All glass intact.
I have two 69 toronados and I never want to get rid if them. I need lots of parts. Window switches/panel, gauge panel/ cluster, hood,front fender/fender chrome, I would love to get a whole car. Can you list how much you want for the parts or for every thing you have? Or anybody with a whole parts car or cheap car. I paid 1800 for the one I drive now renting a dolly and truck cost me another 1500 after milage. And then I had to rebuild the motor, but the car came with two motors and a complete drive system I am in macon georgia area now. But I wish to keep my toronados going and hopefully pass them down(I'm only 39) . This is important americana to me. I can be reached at callclark@hotmail.com thank you in advance. The hood is the most important thing right now. If I violated any rules of this forum just let me know and I'll edit it to confirm to rules.
Old May 31, 2013 | 10:47 AM
wikkonado's Avatar
I have everything you listed, as well as the whole car still.
I'll send you an email.
Old Jun 18, 2013 | 01:10 PM
CJC's Avatar
CJC
Fuel Sender
I acquired some parts from you previously-Do you have the fuel sender unit? it is on the top of the fuel tank . Jim
Old Jun 18, 2013 | 08:29 PM
SJL's Avatar
SJL
I'm still interested
The parts
4 hub caps
the window switches and I'll need both harnesses for the switch gear for both doors. windows and door locks. Do you have a rear view mirror as well?
Email me with the prices
Steve
Old Mar 22, 2014 | 10:29 AM
OCD4life's Avatar
Any parts still for sale?
Old Mar 22, 2014 | 11:32 AM
wikkonado's Avatar
Car is gone, sorry! Lock 'er up.
Old Mar 22, 2014 | 11:43 AM
  #31
OCD4life's Avatar
Locker up?
Old Apr 29, 2014 | 09:25 AM
  #32
OCD4life's Avatar
i need 69 toronado parts please text me 2623665929
Old Jun 19, 2014 | 05:01 AM
  #33
Olds69swe's Avatar
steering wheel
The horn pad is good.[/QUOTE]
Is the steering wheel sold?
Old Sep 3, 2014 | 03:39 PM
  #34
saxtgrn's Avatar
Toronado Right Tail Light Lens
I am looking for the right tail light lens for a 69 Toronado. Do you have one that you would be willing to sell?
Tom Saxton
707-536-7554 please call or text me
buickfarmer
May 10, 2012 05:44 PM
Greg McDonnell
Feb 28, 2009 06:54 PM
junkman67
Sep 10, 2008 05:32 PM
