Headlight Cannisters!!!!
Old Dec 19, 2014 | 04:37 PM
Majordan's Avatar
Angry Headlight Cannisters!!!!
OK, I surrender. Where can I find replacements for my 66 Toro. Ken no longer rebuilds them, where do I go......?
Old Dec 19, 2014 | 05:08 PM
Octania's Avatar
Why not adapt Corvettish electric actuators?
Old Dec 20, 2014 | 12:15 PM
oldave55's Avatar
Octania, I am interested in converting my '66. Do you have any information on parts and procedures for the corvette installation or know anyone that does? If you have any such data, please let me know in this CO post or at: mccord.arch@sbcglobal.net thanks!
Old Dec 20, 2014 | 07:29 PM
Octania's Avatar
not directly, but I know the 83? Vette has fast acting electic actuators. Should not be hard to modify for the correct stroke and then wire to the headlight circuit. Maybe there is a business opportunity here. It's a linear actuator, pretty well understood things. I used to work at a company that made power seat motors, little lead screw actuators. Slow moving of course. Only 3-4" of travel typically, and quite strong at about 600 lbs axial load stall force. My job was to run them to death on the durability tester.
Old Dec 20, 2014 | 08:52 PM
redoldsman's Avatar
Proud Viet Nam Veteran
83 Vette. Really? There were none. Maybe 84 will work.
Old Dec 21, 2014 | 08:10 AM
bluecab's Avatar
Mostly Gristle
There has been a bunch of discussion of this over at the TOA forum.
I plan to use linear actuators on mine when I get to that point.
Here is a company that makes them:
https://www.anaheimautomation.com/ma....T0drlKu2.dpbs
and another:
http://www.aeicomp.com/search_result...GORY=Actuators
I have not looked at the wiring required to use either a stock Toro switch or a more generic GM switch of the era, but I'm sure that the wiring would be simple enough.
Fabricating the mounting brackets and pivots would seem to me to be the biggest part of the conversion.
David
Old Oct 18, 2015 | 01:59 PM
barrymb's Avatar
I have been experimenting with making the Toronado headlamp actuators on a 3D Printer. If you're patient, I will have one available in a few weeks.
Old Oct 18, 2015 | 02:00 PM
barrymb's Avatar
I have also managed to make the turn signal actuator for a 66 Toronado.
Old Oct 27, 2015 | 12:56 PM
cadillac kevin's Avatar
turn signal actuator? you mean the part in the column? (mines out on my good 66).
as for the cannisters, that would be awesome if they could be 3d printed. the P.O. of my 66 had to buy another car to get good working ones (and I'd rather not have to do the same when one of mine go out)
Old May 2, 2016 | 03:19 AM
oldsmobilia's Avatar
Last I checked a year or two ago Speciality in Michigan makes them
PalmSpringsOlds
Jul 12, 2012 10:04 AM
fred a
Tech Editor's Desk
Feb 16, 2012 05:01 PM
Richie
Feb 14, 2005 02:49 PM
texasred
Apr 19, 2004 01:07 PM
