Fixing '66 Toro trim rings?
Old Dec 29, 2015 | 05:10 PM
Paxtonshelby's Avatar
Hi guys - has anyone found a way to fix / replace broken tabs on wheel trim rings? My rings are in good shape cosmetically but they are all missing one or more tabs. I'd rather not pay big bucks for rings in perfect shape, as my car is going to be a driver. Looking at the rings it seems that there might be a enough room / thickness to remove the existing tabs and rivet on new ones. What do you think? Also - what kind of steel would be best to use? I don't want these things to break every time I remove the ring from the wheel. Any help you can offer will be greatly appreciated!
Old Dec 30, 2015 | 05:52 PM
Anybody?
Old Dec 30, 2015 | 06:18 PM
cherokeepeople's Avatar
i think if i dug i could find a dozen toro rings in the ring pile.and not one of em has all the clips.
Octania's Avatar
Nope, nobody
I looked at that years ago. Not worth the trouble.
Get the right steel
form it right
heat treat it
attach it
Quite a project.
Maybe tack weld 'em on? Re-riveting would require dimantling [ruining] the SS ring.
There you go, used originals maybe
I had used to have some with the tabs all intact...
Old Dec 30, 2015 | 08:01 PM
I hear ya guys - looks like I will try to fab up some tabs. Once they fit I will probably us some lithium grease on them so they glide and don't bind.
Old Jan 1, 2016 | 12:25 PM
Toro X6's Avatar
Has anyone found a trim ring from another vehicle or the aftermarket that fits and looks similar to the OE?
sgtoro
Aug 25, 2011 08:47 AM
Olds64
49
Jul 17, 2009 10:00 AM
American Lead
Mar 13, 2009 07:22 PM
The Stickman
Mar 13, 2009 05:45 PM
Allan R
Jul 21, 2008 11:34 AM
