Comfortron help
Old January 26th, 2022 | 09:50 PM
  #81
sgolds's Avatar
Originally Posted by bw1339
Check that these components have power (in this order)
- Master switch
- Power servo
- Range relay (on passenger side inner fender)
- Fan
What does the range relay look like? Is it near the starter solenoid?
Old January 27th, 2022 | 02:37 PM
  #82
sgolds's Avatar
I got the fan back, I didn't plug the resistor back in correctly. still no heat though
I put vacuum to each of the 3 small ports on top of the servo, but I didn't see anything inside move. Should I be seeing something moving that's attached to that small round thingy with the 3 ports on top?
Old January 27th, 2022 | 04:46 PM
  #83
bw1339's Avatar
Are you getting cold air? To get heat, the actuator in the power servo must be getting vacuum, making the arm retract and turning the blend door to HEAT.
It's also possible that the heater valve is not opening.
Old January 28th, 2022 | 01:38 PM
  #84
sgolds's Avatar
All hoses connected to the heater valve are hot, so I guess that is working. I put engine vacuum on the under hood servo and it moved the arm, but it still was blowing cold.
What does the smaller round piece on top with the 3 small vac lines do?
Old January 28th, 2022 | 05:17 PM
  #85
bw1339's Avatar
The round thing is a rotary vacuum valve. Depending on what the power servo wants (Heat or cold), it moves the doors in the dash. I believe it also opens/closes the heater valve.
I would clean the electric contacts and put a thin layer of dielectric grease over them.
Old January 30th, 2022 | 09:34 AM
  #86
sgolds's Avatar
Thx, what are those 3 vac ports for? Looks like they go to to the master switch, I'm assuming they control the fan speed? Also where are those electric contacts?
Old January 30th, 2022 | 09:39 AM
  #87
bw1339's Avatar
Those vacuum ports control the doors in the dash (and heater valve, I believe), so that the system does what the power servo dictates. Fan speed is controlled by the electric contacts in your photo, which route power through the resistors in the power servo.
Additionally, the Range Relay (passenger side wheelwell), gives two speeds to the entire range, controlled by the lever in your control panel (High or Low).
Old January 30th, 2022 | 09:58 AM
  #88
bw1339's Avatar
Master switch supplies 12V to the entire system. It does not control fan speed. Think of it as a vacuum actuated electric relay.
Old January 30th, 2022 | 10:01 AM
  #89
sgolds's Avatar
So if I put vacuum to any of those 3 ports I should see or hear something move?
What part is the electric contacts and also what does tgAt range relay look like? I don't see anything on the pass wheel well
Old February 15th, 2022 | 06:01 PM
  #90
sgolds's Avatar
Ok, took it out since the weather was ok. Fan was on high the whole time, even with the car still cold, but now it's coming out of the vents. Still no heat though. I put engine vacuum to the servo and the arm moved to the other side, and the fan shut off. Came back when I put the delay valve thingy back on the servo.
Don't know why I still can't get the heat to work though. The servo moves the door correctly on top of the cowl, and both heater hoses are hot on each side of the heater valve.
Old February 15th, 2022 | 06:23 PM
  #91
bw1339's Avatar
Out of curiosity, where are you located?
Old February 15th, 2022 | 07:28 PM
  #92
sgolds's Avatar
I'm in NJ
Old March 7th, 2022 | 05:40 PM
  #93
sgolds's Avatar
Anyone know what the spring with the screw attached on the blend door lever is for? It's on the piece on top of the firewall that the servo pulls back and forth. Is there a specific way to adjust the screw? I'm assuming that's what determines how much hot or cold air comes inside ?
Old March 7th, 2022 | 05:42 PM
  #94
bw1339's Avatar
That spring is there to allow some overtravel without straining the power servo or the blend door. Just make sure you get full travel in either direction.
Old March 7th, 2022 | 06:05 PM
  #95
Loaded68W34's Avatar
Also, it allows you to adjust the door for the full closed/ full open postion. the screw lets you adjust the center position of the door and then the spring allows it to over-run as stated above.
Old March 8th, 2022 | 01:39 PM
  #96
sgolds's Avatar
Just curious, how can you tell if it's adjusted properly?
Old March 8th, 2022 | 02:41 PM
  #97
The plastic part attached to the blend door should not bottom out on the end of the slot in the power servo arm (fully open or fully closed).
Old March 8th, 2022 | 04:03 PM
  #98
bw1339's Avatar
The way I do it is putting a vacuum to the Power Servo, so that it goes into HOT mode. When the vacuum is released and the arm retracts, you want the overtravel spring to compress slightly, signifying that the blend door has reached its stop.
Old March 10th, 2022 | 12:32 PM
  #99
sgolds's Avatar
Can I do this by putting engine vacuum on the servo? Which spring is that over travel spring, is it the small one with the bolt attached or the large one on the other end?
Old March 10th, 2022 | 05:12 PM
  #100
bw1339's Avatar
Any vacuum source you want. You can even suck through a hose.
The second spring (I'm trying to remember what it looks like), I believe provides an overtravel protection on the other side of the stroke.
Old May 2nd, 2023 | 01:35 PM
  #101
sgolds's Avatar
Hey, back again !
I've managed to manually move the lever on the firewall back and forth, changing from heat to cool, bypassing the auto part. Crude but it works and I don't have to do it that many times during the season
My issue now is that the air is only coming out of the vents, how can I get it to the floor when I'm using the heat?
Old May 2nd, 2023 | 01:37 PM
  #102
bw1339's Avatar
What you are asking is done by the master servo. Rather than manually move the blend door, you are better off using the vacuum regulator I suggested and let the master servo do its thing.
It controls:
- Fan speed
- Where the air comes from
- Air temperature
jpfiff68@gmail.com
December 29th, 2021 05:38 AM
304forest
February 2nd, 2015 07:58 AM
1BOSS83
April 16th, 2013 07:52 PM
86Regency
May 9th, 2011 05:07 PM
redvettemike
June 18th, 2009 02:38 AM
Quick Reply: Comfortron help
