69 Toro Output Shaft assembly needed
Old Mar 24, 2012 | 11:02 AM
Frogge467's Avatar
67 Toro
Is anyone parting out a 69 Toro? I need the output shaft (jack shaft) assembly. Let me know. The front pinion bearing in my 67 differential blew apart and ruined the diff. I have a diff from a 69 that is fine, unfortunately the output shafts are different.
Old Mar 24, 2012 | 11:24 AM
2blu442's Avatar
If you haven't looked through the parts for sale section you might give that a try. I believe there's been a couple 1968-69 Toro's being parted out in the last year. Too bad I'm on the other side of the country, I've got several 1966-67 transmissions/transaxles from Toronado's. If you don't find something closer, I still have this:
https://classicoldsmobile.com/forums...ferential.html
John
Old Mar 24, 2012 | 04:04 PM
Frogge467's Avatar
67 Toro
67 Toro differential EPIC FAIL
Chunks out of diff cover, pinion gear chewed up & 69 differential.
Old Apr 7, 2012 | 08:44 PM
wills30's Avatar
I'm pick up a complete 69 tor , monday i may have the part you need
Old Apr 8, 2012 | 09:18 AM
RATCHETMASTER's Avatar
"I reckon so!"
Did you mean you are looking for a 67 Toro output? You have a 69 set up that is different and you need a 67 setup?
I didn't know they were different. Ratio different?
Aceshigh
Dec 9, 2013 09:56 AM
kartmaster
Sep 13, 2012 07:57 PM
Frogge467
Mar 24, 2012 11:09 PM
MLK-442
Mar 21, 2012 11:08 AM
drewt
Mar 16, 2010 07:18 PM
