66 Toro, High rpms/engine straining on highway
Old May 20, 2023 | 08:17 PM
sgolds's Avatar
66 Toronado, I'm starting to notice that as you approach about 50 mph and higher the engine starts straining and spinning faster and faster.
Goes thru all 3 gears normally but something happens in that speed range (and higher).
It's def. in 3rd gear, but feels like I have to push the gas pedal harder to keep it going, and that makes the engine spin faster the faster I go.
The kickdown switch doesn't work, but I can downshift into 2 by pulling the trans lever, so I know it's in 3rd gear.
I hope this is not a transmission problem. Any ideas?
Old May 20, 2023 | 08:32 PM
Sugar Bear's Avatar
Check the ATF level and condition.
Good luck!!!
Old May 21, 2023 | 05:57 AM
rocketraider's Avatar
Oldsdruid
The kickdown switch also controls the switch pitch torque converter. If it's misadjusted or not working the TC may be stuck in the wrong stator angle.
Old May 21, 2023 | 01:47 PM
cfair's Avatar
Here’s what little I know about those kickdown & switch-pitch switches:
https://classicoldsmobile.com/forums...vicing-149216/
Chris
Old May 24, 2023 | 03:46 PM
sgolds's Avatar
Does that mean I shouldn't be driving it with the switch unplugged?
TenMidgets
Nov 25, 2015 10:11 AM
bw1339
Jul 21, 2015 02:01 PM
White_Knuckles
Jun 5, 2013 09:46 PM
guy.graziano
Jun 13, 2012 05:33 AM
theone81
Drivetrain/Differentials
May 20, 2008 01:14 PM
