'66 Toro heat riser question
Old Feb 9, 2016 | 06:17 PM
Pete Kaczmarski's Avatar
My car has 47k original miles and last year it developed a slight by annoying exhaust leak. It is leaking where the shaft of the heat riser valve comes thru the exhaust manifold. Is there a sleeve that is cut to go over the shaft and into the manifold or any other ideas......Thanks
P.S. the heat riser still works
Old Feb 9, 2016 | 07:19 PM
timb's Avatar
i hope so mine will need the same thing .it's leaking at the seal so bad i can't tell if the shaft is leaking.
dingusboy
Mar 8, 2014 07:09 AM
1977 Delta 88 Flint
Dec 24, 2012 11:25 PM
Ian U
Jul 7, 2010 01:39 PM
StickW31
Jan 21, 2010 08:12 AM
bjtstarfire
Nov 13, 2008 02:04 PM
