Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
442 TO code differential help
Old Jun 5, 2015 | 05:51 AM
Rocketguy's Avatar
I have a '71 442 with the stock TO code 3.73 and I'm looking to install a 3.42 so I can enjoy the car on the highway a bit more.
I've read that all '71 442s came with the corporate GM axle and not a type "O". Is this true for all axles including the heavy duty G89 "TO"?
Is there a guide on the net somewhere that will help me ID my axle?
Old Jun 5, 2015 | 06:10 AM
oldsmobiledave's Avatar
fyi
Your car was built with the 8.5" 10 bolt. You can reuse your existing posi carrier & install 2.73, 3.08, 3.23 or 3.42 gear sets. If you have not already obtained the 3.42 gears you might consider one of the other ratios but first & foremost decide how tall a rear tire you will be running. 3.23 gears are an excellent compromise between performance & cruise RPM.
Old Jun 5, 2015 | 06:23 AM
svnt442's Avatar
I had 3.23 gears in both my 70 and an 80 and they are a great all around gear if you don't have overdrive.
Old Jun 5, 2015 | 07:09 AM
Rocketguy's Avatar
Thank you : )
Maybe the 3.23 is a better gear for me.
The first thing they ask when I call a shop to have this done is which axle I have. Can you help me verify that the G89 is a corporate 10 bolt and not an O type axle?
Old Jun 5, 2015 | 07:42 AM
svnt442's Avatar
The carriers are the same in 71. The difference is if you have bolt in axles or not. From 67-70 everything was different.
Freddy B
Jun 2, 2015 10:54 PM
electra483
Oct 18, 2013 05:58 PM
nj_cutlass72
Drivetrain/Differentials
Mar 18, 2013 04:31 AM
boondocker
Feb 24, 2011 05:04 AM
frasco
Jan 18, 2011 12:21 AM
