Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
1965 Dec Service Guild - Toronado Axle Torque
Old Jan 15, 2026 | 07:31 AM
ourkid2000's Avatar
Anyone have the 1965 December Olds Service Guild publication? If you do, could you check the section on pg 98 referring to the Toronado axle torque for me? I'm suspecting the '66 CSM has incorrect values for the axle torque and I'm wondering if this service guild clarifies the proceedure. I found a snap shot of that issue and noticed the table of contents references the axle torque for the Toro.
Old Jan 15, 2026 | 07:45 AM
Rallye469's Avatar
I think I have them all for 6r…but I’m in Miami for the next couple days.
Old Jan 15, 2026 | 07:49 AM
ourkid2000's Avatar
Thank you sir!
Old Jan 16, 2026 | 05:33 PM
I have it but I'm also out of town until late Saturday.
Old Jan 16, 2026 | 06:00 PM
ourkid2000's Avatar
Thanks everyone, appreciate you checking if you get a chance. Cheers! I've actually purchased a 1965 set off of Ebay but it will be some time before it arrives up here to Canada. It had more Toronado information in it than I was anticipating.
Old Jan 19, 2026 | 02:26 PM
ourkid2000's Avatar
Just following up on this to see if anyone has had a chance to check the information in the service guild for me? Thanks again!
Old Jan 24, 2026 | 01:28 PM
ourkid2000's Avatar
Well I just took care of this myself.
So if anyone out there has a 1966 Toronado and you've been playing around with your front axles or front wheel bearings the torque spec in the CSM is VERY wrong. The December issue of the 1965 Service Guild addresses this with the correct spec of 110 ft-lbs minimum and NOT the 65 ft-lbs called out in the '66 CSM. The nut should be torqued to 110 ft-lbs and if you cannot get the cotter pin through, you must tighten to align it rather than loosen.
This is right out of the Oldsmobile Service Guild and I knew something was wrong here, I just couldn't prove it until now. All this time I didn't know there was Toronado information in the 1965 publications but it makes sense, I suppose, considering some would have been produced towards the end of '65 with the '66 models coming out that Fall.
ourkid2000
Jan 29, 2026 03:39 AM
Gauchobyte
Apr 7, 2022 07:56 AM
lawsrolf
Nov 23, 2020 04:42 AM
okie88
May 17, 2019 03:51 PM
kanskidoo
Jan 5, 2011 08:59 AM
