Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
What is it?
Old Aug 28, 2013 | 06:44 AM
Jedrzej's Avatar
What is it?
Hello. I have a problem with my automatic gearbox. If I start push accelerator I need waiting to car start to realy high RPM and if I push pedal to the metal I can't make a burnout. Oil is ok, I found one vaccum pipe (blue), but today I found something more (green):
Please, tell me what is it (green wheel).
Old Aug 28, 2013 | 06:53 AM
tru-blue 442's Avatar
Old School Olds
The one in the green circle is a vent.
Make sure it has no restictions, 'dirt dobbers, etc.'
It is supposed to be open. Just like it looks.
The one in the red circle should go to your vaccume
modulator,'the rusting looking can in the pic.'
The problem you describe sounds like low
of fluid. Did you check it at operating temp, at idle
on a level surface?
