Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Switch pitch trans
Old May 4th, 2015, 10:26 PM
Kid Thunder's Avatar
Switch pitch trans
Joe Pad,
Whey do you think Olds choose to use the switch pitch only for 3 model years?
Cost, fuel mileage, the advent of the Turbo 350 or what ever. It makes a world difference in the way my 67 Cutlass 330 2bbl Jetaway trans runs. Much easier in around town stuff & in all out running. It's like having 2 torque converters in one transmission!
Don-M
Kid Thunder is offline
Old May 5th, 2015, 07:03 AM
Originally Posted by Kid Thunder
Joe Pad,
Don-M
Four model years, actually - 1947-1967. I don't know why they dropped it, except possibly because the increasing HP and torque of the late 1960s made the switch pitch redundant. Note also that the 1961-63 Olds transmissions like the RotoHydro5 in my 62 F-85 had a similar method of providing an additional "passing gear" by alternately using then locking the fluid coupling while in second.
joe_padavano is offline
Old May 5th, 2015, 08:19 AM
jaunty75's Avatar
The new math.
jaunty75 is offline
Old May 5th, 2015, 08:22 AM
jensenracing77's Avatar
My transmission guy said it was a money thing. He said the gain was not that big of a deal to the general public and not worth the extra in manufacturing.
jensenracing77 is offline
Old May 5th, 2015, 08:38 AM
Originally Posted by jaunty75
The new math.
Well, 1947 is ALMOST 1964...
I'm sure that was a very big part of it. I can't really see the need for a switch pitch torque converter when you have 500 ft-lbs or torque. It actually makes a lot more sense for a radical cam. I built a 71 one time and used the switch pitch wired to the brake switch. With your foot on the brake, the converter went to high stall, making it easier to sit with the trans in drive. A separate switch also allowed you to select the high stall for launching the car off the line.
Old May 10th, 2015, 08:54 PM
You are right Joe, with 500 lb-ft of torque it's not needed but with a 330 2bbl it sure comes in handy!
hotrodpc
28
February 12th, 2015 06:06 AM
197064buickspec
August 10th, 2014 06:05 PM
67cutlass67GS
May 25th, 2012 02:13 PM
WTony
July 3rd, 2010 10:50 AM
|-K|=K
September 29th, 2009 10:55 AM
Quick Reply: Switch pitch trans
