Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Index mark - choke cover
Old Dec 22, 2017 | 08:59 AM
Turnpike's Avatar
The mark (index?) located near the "DIV" on my choke cover, how is that exact location established? Meaning, was that the specific location of the mark on all 1968 covers (7031484)? Added note: the parts manual shows this # covers '66 to '68.
Or was it based on GM testing each cover/coil and making the mark (which would seem odd with mass production)?
Old Dec 22, 2017 | 09:30 AM
The index mark has always been the starting point, it could turn out to be either left or right of there depending on the coil inside.
Old Dec 22, 2017 | 09:36 AM
classicmuscle442's Avatar
Index mark is on the top edge, the cover you show has half of the spot where you put screwdriver in is broke off. Setting was set on carb cold before factory installed them, so that choke just closed and locked down.
Old Dec 22, 2017 | 10:45 AM
Each coil is slightly different in response. I suspect there might have been a calibration step when the coils were assembled and thus the scribe mark on each (as opposed to a line cast into the cover at the same time as the lettering). The CSM lists the proper alignment for the choke. Most are set at zero, but some are supposed to be plus one or minus one mark.
Old Dec 22, 2017 | 12:26 PM
Turnpike's Avatar
Thank you for the responses. I was curious.
240 Gordy
Oct 11, 2020 10:04 AM
Nov 13, 2011 01:31 PM
69 Ragtop
Nov 17, 2010 07:36 PM
tmbrennan
Apr 6, 2010 09:29 AM
Lady72nRob71
Mar 23, 2010 08:48 AM
