Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
GM VIN Decoder 1972-2009
Old Jan 5, 2009 | 11:54 AM
With AOL Hometown shutting down, Drew Senko's Oldsmobile VIN decoder is offline. I stumbled across this link from the GM Service organization. Very helpful.
http://service.gm.com/dealerworld/vincards/
Old Jan 5, 2009 | 01:26 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
That is VERY helpful. Thanks for unearthing it.
Old Jan 6, 2009 | 02:24 AM
88 coupe's Avatar
Junior Member
This one still works: http://www.v8cars.hu/oldsvin/decode.php
Norm
Old Jan 18, 2009 | 12:50 AM
egknz's Avatar
1972 Cutlass Supreme 455
love the vin decode site
This is What my Vin pulled upYear:1972Division:OldsmobileSeries:Cutlass SupremeBody:Holiday Hardtop (2 door)Engine:350 (5.7) V8 4BBLPlant:Arlington, TexasSerial Number:183198My ?? is what kind of motor came in these cars that year ?? 442,403,455,350 and did some of these cars have the dual gate shift avail ???my does have floor shifter but my console was all ready gone.
Old Jun 17, 2009 | 01:48 AM
kurtdaniel's Avatar
Good thing you’ve stumbled across this link..its really helpful for me too..i hope mazda parts has this decoders too..
Old Oct 12, 2010 | 12:17 PM
fmbjogger's Avatar
Thanks also. Just took delivery of a 75 Olds Delta 88 that was advertised as a 350 4bbl. Vin shows engine code "T" = 455 4BBl.....sweetens the deal even more !
Old Oct 12, 2010 | 03:37 PM
Just be careful that the engine in the car now may not be the one it was born with.
Old Mar 31, 2011 | 04:55 PM
71'ohiocutlass's Avatar
thank you so much this helped tremendously
Old Apr 3, 2011 | 04:00 PM
GAOldsman's Avatar
"Car"mudgeon
In '72 there was the 350 (standard displacement) and the 455 (optional) and yes the dual gate (W-26) could be ordered in '72. Hope this helps.
Scot
Old Apr 6, 2011 | 08:46 PM
alek72us's Avatar
Olds Dreamer
My ?? is what kind of motor came in these cars that year ?? 442,403,455,350 .
hey egknz What cars came with a 442 in them?
lol
Old Apr 6, 2011 | 08:57 PM
Diego's Avatar
There never was a 442 cid motor.
To be honest, I don't think I ever expected to have to say that to an Olds owner. :-)
Old Apr 6, 2011 | 08:58 PM
Diego's Avatar
On a somewhat related note, I think some of you may find this handy:
http://www.gmheritagecenter.com/gm-h...tion-kits.html
Old Apr 6, 2011 | 09:00 PM
alek72us's Avatar
Olds Dreamer
Excactly i hate it when people come up to me and ask me if there is a 442 ci engine in my car its one of my biggest pet peeves.
it funny when people ask if it has the 442 engine in it because i say the 455 yeah.
Old Apr 6, 2011 | 09:07 PM
Aceshigh's Avatar
Good find Joe. Thanks for the links guys.
Subscribed to keep this in my favorites for future use.
Old May 12, 2011 | 08:24 PM
GAOldsman's Avatar
"Car"mudgeon
I put in the VIN from my wife's grocery getter which is a Tahoe and it gave me FOUR whole pages of RPO codes (options) and stated that the rarity was one of two with the same options and one of six with at least those same options put out by Janesville, WI. Pretty neat stuff, Thanks Joe! There were some RPO's that I didn't understand though. Would you know where I could decode the codes?
Scot
Old May 23, 2011 | 09:53 PM
72old$'s Avatar
Smile Thanks for the info. Decodes my 72 Olds Delta Convert exactly.
Norm
Old Feb 1, 2012 | 10:53 AM
Slomega's Avatar
Some AWESOME links posted in this thread ..... THANK YOU !!
Old Feb 1, 2012 | 11:36 AM
Rickman48's Avatar
Yeah, definatly worth saving!!
Old Feb 20, 2012 | 11:17 PM
oldsguybry's Avatar
NOVICE car nut
I thought I made a comment on this already , my post went away... oh well , good job!!!!
Old May 9, 2014 | 12:22 PM
On the engine stamping pad, under the #1 cylinder. This is called a VIN derivative.
The stamped information (if Olds 403) will be
3 (olds) 7,8,9 (last number of year) (letter code indicating plant) followed by XXXXXX (number sequence of original car)
Old May 9, 2014 | 02:54 PM
Originally Posted by Earls63304
Newbie here, so pls. forgive. Just bought a 1973 Cutlass S (VIN 3G37K3M382291). Owner said that the engine (K code 350) was replaced with newer ('late 70s) 403 c.i. Question: Where on the engine do i look to find the approp. #s to determine the needed specs mechanically, year, etc. (i.e. get the right parts for tune ups, parts replacements when needed)?
As Allan points out, the VIN derivative will tell you the year of the block. It won't tell you the displacement, however. Olds blocks have a casting number on the small shelf above the water pump, next to the oil fill tube. The photo below is of a late 1970s 350 block. Of course, on 403 motors, there's a large "403" cast into each side of the block, where the freeze plugs are.
Old May 9, 2014 | 03:11 PM
Exactly.
The 403 should have a casting number 557265 or 553390. One other point of clarification...just in case. The 403 is a small block engine. Don't be fooled that the 4 in the 403 means its big block. Color on the 403 should be blue, although anyone with a rattle can spray paint can change that to whatever they want.
The 403 is really well marked on the side of the block to the rear of the motor mounts above the frost plugs as Joe mentioned. 403's also have a distinctive valve cover. Note that it uses less bolts to secure, and some of the flanged areas are not pierced to accept VC bolts.
Old May 9, 2014 | 03:22 PM
If you read all of the O.P.'s threads, you'll find out that this 403 has a points distributor, so if it really is a 403, it's apparently a frankenmotor. The original 403 valve covers used five bolts, but without more details on head casting numbers, etc, there's no way of knowing what parts are on that motor. It may just be a 403 short block with other parts from the original 350, or who knows what.
Old May 9, 2014 | 03:33 PM
Hmmm, good 'points'. My vallium must be kicking in from all that caffeine earlier....
It would be helpful if he posted a picture in one of his threads that shows the engine.
Old Jul 6, 2015 | 12:08 PM
Octania's Avatar
I found and used this again today
VERY handy since most of my PN info stops at 1975
http://api.viglink.com/api/click?for...%2Fvincards%2F
Old Jul 6, 2015 | 12:22 PM
It's worth noting that those VIN cards are regularly updated and cover 1972 through the current model year. They have also added pre-72 information, but unfortunately for Chevy only at this time. These come straight from GM Parts, so there is no question that the info is correct.
1970cs
Jan 18, 2012 05:56 AM
gtdrvr
Jan 1, 2012 08:08 AM
decodethis
Dec 17, 2011 03:18 PM
Jamesbo
Nov 21, 2008 04:34 PM
65 Dynamic 88
Feb 26, 2008 04:57 PM
