Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Engine date code lead time to Trim plate date
Old Aug 17, 2013 | 07:41 AM
1320dragmonza's Avatar
What would one expect for normal lead time of a date code of 295 on the block to install in a chassis. My 72 Cutlass Supreme conv. has a Trim plate with 3rd week in Dec. build date.
Also of note the heads have different date codes of 303 and 306, I assume that would be within normal resonability of building an engine, correct?
And lastly what would be the most days between head date codes, I have a set of Ga heads with 101 days between the cast dates? Both came off of a what seems unmolested engine.
Old Aug 17, 2013 | 07:55 AM
If it's not the original engine from the car, I wouldn't be concerned about the date code issues in the slightest. The original engine will have Div/yr/factory and last 6 of VIN stamped on the stamping pad of the engine.
Old Aug 17, 2013 | 12:11 PM
stevengerard's Avatar
those dates seem to correlate fine with your car. The one set of heads does seem like a big gap - 101 days but who knows. I've seen lots of cars with heads from a few days to a few weeks difference.
Old Aug 17, 2013 | 01:51 PM
^^^ This.
The VIN derivative stamp will tell you if the block is correct. The date code is irrelevant if it's not original. As for the heads and other parts not VIN-stamped, 30 days prior to the build date is typical, 90 days is about the accepted limit.
Old Aug 17, 2013 | 04:44 PM
wmachine's Avatar
Trying to remember member
^^^ This.
X3. Way too much has been made about trying to "match" a date to a replacement part. It is borderline absurd. A date in itself is not something that makes a part any more correct. It is either original or not. If it is not original, it is either correct or not. If the part number is correct (with correct internals), it is the correct part. Period. That is what part number are for.
Boiler_81
Sep 22, 2020 02:05 AM
GEARMAN69
May 22, 2015 10:58 AM
SX71olds
Jul 25, 2014 08:17 AM
gmsteve455
Mar 25, 2014 07:02 PM
Boldsmobile
Nov 2, 2011 06:02 PM
