Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
72 Old Cutluss ~ Problem
Old Oct 21, 2009 | 09:14 AM
dale.rainier's Avatar
Hey, I am having a problem where when I turn the key the starter doesnt turn really nothing happens at all (did check the fuse), but I am able to jump the starter and the car runs fine. Battery and Alt are good. Any ideas what could be the problem.
Old Oct 21, 2009 | 09:33 AM
70 cutlass s's Avatar
Check the wire going to starter to see if its hot when the key at the start pos. Might want to check the linkage go from the trans to the steering column make sure its adjust right or the neutral safety switch would keep it from starting. Also might to check the wire going from the starter to the coil.
Old Oct 21, 2009 | 02:25 PM
72 cutlass455's Avatar
Could be a bad starter solenoid .
Old Oct 21, 2009 | 02:27 PM
lovemy69olds's Avatar
get the old test light out.
Old Oct 21, 2009 | 03:33 PM
bcracing's Avatar
If you don't have power at the starter. May be the netural safty switch itself. Try starting it in netrual. or pulling up on the shifter.
Oldlords
Jan 5, 2015 07:48 PM
Rowdies
Feb 10, 2012 07:57 PM
Mochi
Nov 20, 2010 01:32 PM
Biothree
Jun 30, 2010 09:00 AM
TheConcierge
Nov 1, 2007 01:07 PM
