Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
1961 Steering componenets
Old May 17, 2017 | 06:28 AM
mjmyaire's Avatar
Replacing the steering components on a 1961 Starfire. Initially looked like Saginaw was the way to go but am finding the inner tie rods are difficult to find. I bought a center link on eBay advertised as saginaw but when I received it determined it was Alternate. Alternate I have found is Thompson which is also TRW. Determined it was Alternate because of the tapered socket and the stud measurement that goes into pitman arm. I'm also finding on the Alternate route the pitman arm is difficult to find. My confusion is what works with what and what works with both. It would seem the idler arm will work with both styles but the pitman arm has to be one or the other to match the center link. I don't believe the gear on the steering box matters on that end of the pitman arm....same for both styles. Will the inner tie rods work for both styles? My understanding is the outer tie rods will not work for both styles? Will the sleeve between the inners and outers work for both? How does MOOG fit into all this. On eBay outer tie rod part numbers are all over the board for '61, ES300L, ES 299R, M331, ES300RL, 583246, 583247, 583418, 583419, ES303R, 5303L, 5303R, 5678191, 5678192, 5676916. Those numbers are all for outer tie rods!! Very confused!!! Help!!
mjmyaire
Dec 15, 2016 10:26 AM
1967camaro
Jul 23, 2014 08:32 AM
oldrelics
Mar 24, 2014 06:02 PM
toymobile
Sep 21, 2011 01:01 PM
KQQLCAT
Jun 4, 2009 07:23 AM
