Will this rub?
Will this rub?
ok i got a 87 delta 88 FWD:
i was looking at rims and tires for it to get rid of the crappy steel rims and i came across a set of 225-40zr18 tire with. The place obv tells me what I want to hear and says they wont rub. But Im wondering if any of you would know?
btw setup right now is 205-75R14
Someone help?
Someone help?
will this rub?
I would really dont know what there designed for. There jsut at a local rim and tire shop so who knows really. I jsut didnt know if there would be enough room to fit the 20 extra mm of tire width. But of coarse the shop is no help they jsut wanna make a sale.
Someone help?
Someone help?
By the way, those new tires are about 3/4" wider than the originals but about an inch SMALLER in outside diameter. If the wheel offset keeps the tire centered in the wheel well, you should have no problems. On the other hand, I personally don't care for the extra daylight between the wheel well opening and the smaller tire. Your car, your call.
