upper control arm bushings
Old June 16th, 2014, 07:04 PM
johnnyjaws's Avatar
I just replaced all my ball joints and upper and lower control arm bushings. Is there a tourqe spec for tighting up the upper and lower control arms. the side bolts on the top upper control arm. sorry the car is a 1970 cutlass s
johnnyjaws is offline
Old June 16th, 2014, 07:15 PM
Here you go, right out of the 1970 Olds CSM. NOTE: the * is with the weight of the car on suspension
Allan R is offline
Old June 16th, 2014, 07:27 PM
johnnyjaws's Avatar
Thank you !!
Old June 16th, 2014, 08:48 PM
Sugar Bear's Avatar
Full weight on the car prior to tightening is CRITICAL to the life of the bushings. This puts the bushings in the proper position with a neutral torsion under most conditions instead of being under torsion all the time. BTW I am not anything close to an engineer but "neutral torsion" just sounded cool. It may even be a newly discovered oxymoron?
Sugar Bear is offline
ithaca4me
July 30th, 2011 02:26 PM
mcutlass1969
August 2nd, 2010 11:27 AM
bigwillystyle
December 21st, 2009 10:05 AM
therobski
October 24th, 2009 01:54 PM
tiparosa
February 26th, 2007 10:43 PM
Quick Reply: upper control arm bushings
