Steering Column Rebuild
Old Sep 13, 2022 | 08:11 PM
72skytop's Avatar
I am working on a 1973 Hurst/Olds with a tilt floor shift column.
The shaft wiggle badly at the top and the turn signal stuff seems to be missing plus I think whatever works the horn is missing.
Does anyone have a place they can suggest to send this to so it can be restored where It is tight, the turn signals work and the ignition works properly?
Kevin Korff
Evansville, IN
Old Sep 14, 2022 | 06:18 AM
The GM tilt column wiggle is a common problem. Here's a website that tells you how to correct it. It is quite easy to do yourself.
MichiDan
Nov 28, 2020 07:34 AM
BeenThere
Jul 24, 2016 09:18 AM
BeenThere
Aug 15, 2015 06:19 AM
BeenThere
Sep 6, 2014 07:06 AM
69442
Jul 27, 2012 05:02 PM
