Rag Joint - space between gear box
Old Mar 11, 2021 | 05:11 PM
sschevellecutlass_Bob's Avatar
Hope ya'll are well. 1970 Cutlass Making the GCJ steering box change......took some pics before disassembly but missed a detail... when installing the rag joint onto the steering box spline, should the rag joint be touching the surface of the box or do I leave a little space between them? Thanks
found below on line - seem correct?
All hardware is included. Machining tolerances are tight, so depending on your gearbox, initial spline fitment may take some finessing. But once mated and the set screw secure, everything is rock solid. Don't forget to leave about 1/8" to 3/16" space between the steering box and rag joint.
Last edited by sschevellecutlass_Bob; Mar 11, 2021 at 05:16 PM. Reason: found material to add
TommyTheCat
Jun 29, 2020 11:02 AM
AZ442
Suspension & Handling
141
Jan 20, 2020 03:49 PM
mzbk2l
Mar 6, 2014 08:35 AM
veltboy618
Sep 24, 2010 05:49 PM
MJAKS462
Aug 17, 2010 03:19 AM
