over sized front sway bar - tires barely
rub on the inside sidewall when the steering wheel is turned all the way . They are P235 60 r 15.....any thoughts or suggestions on a slightly narrower tire? 225 or one more step down?? BF G radial TAs, getting ready to order a new set.
Thanks!
Thanks!
I have a 1.25" bar on the front of my 72 supreme w 255-60-15s on ss3s no sway bar rub at all!
What size and kind of sway bar? What rim offset? Changing tire size may work, but it would appear something else is causing the issue.
It is the BMR one 1.25, stock ss3's too. the "rub" is no more than making the sidewall shiny, that is how i noticed. nothing wrong handling wise and i have to crank the wheel to get it close- cant make it touch by sitting still, only under driving load......thanks for the thoughts........more? i should add i have 1" lowered front springs too, make a diff at all?
2 sets of these:
https://www.summitracing.com/parts/trd-4082/overview/
I like stock ride height
no need for GIANT sway bars
instead of drop an inch
get the HO specialties A Body kit
Larger GM brakes and well planned out steering enhancement
like my mickey thompson 255/60/15 all 4 corners
PM70
May 11, 2017 10:59 AM
PM70
May 3, 2017 02:59 PM
