how to uncouple rag joint...?
Old April 25th, 2011 | 03:36 AM
STLCRZY's Avatar
Hi guys,
wanted to uncouple the rag joint but canīt separate the two bolts in the picture.
I tried a few hours...with heat and violence and and and..have no more ideas.
Are this bolts threaded ?
Old April 25th, 2011 | 04:30 AM
Are you trying to remove those two welded-on pins?
The bolts are already out in that picture.
If those are what you're trying to remove, might I ask, Why?
IN general, the rag joint is a single part that connects the flat plate flange of the steering column end to the splined input shaft of the steering box. Some (ie: Chevelle SS and tilt / telescope) connect to a separate piece on the steering column side that then connects to the steering column via a splined fitting (see attached illustrations). It does not require disassembly.
Old April 25th, 2011 | 12:16 PM
STLCRZY's Avatar
Yes, trying to remove this pins to install new rubber....is it possible or must buy new complete r.joint?
regards
Old April 25th, 2011 | 04:02 PM
Hmmmm... I never heard of anyone replacing the rubber, or even needing to (though I see you've got a new piece of rubber there, so I guess they sell 'em).
You've got me, but my guess would be that you can't do it - the junkyard's got hundreds of 'em, though .
Old April 25th, 2011 | 06:28 PM
66luvr's Avatar
Yes it is done all the time.
The bolts you can't remove are actually rivets. This is what I do, not to say there aren't many more ways.
I grind off the heads of the rivets on the back side you didn't show in your pics, then drive them out with a punch. I buy a kit from the "Help" section at the parts store which comes with 2 extra bolts designed to take the place of the rivets. Just bolt it back together using the new parts. I sorta thought the kits had a small instruction sheet in them.
One thing you should know, the parts are "clocked" and like a distributor can be installed 180 degrees out. The flanges generally only fit on the shafts in one location (at least on the 64-67 stuff I generally mess with). So if you have them put together wrong you can wind up with the steering wheel upside down. Also the brass/copper thing is a ground strap for the horn so it needs to be in good shape and properly installed.
Good luck,
Mike
Old April 25th, 2011 | 06:32 PM
Wow. You learn something every day.
I've had a lot of GM cars, and have never had one that seemed even close to needing the rag joint rubber replaced.
Now I know.
Old April 25th, 2011 | 07:18 PM
gearheads78's Avatar
car guy
Now I know.
One of the first things I replace if a car was been sitting a long time. They rot and tear all the time in this climate.
Old April 25th, 2011 | 07:35 PM
Ahhhhh... Here they're preserved by the cold .
Old April 25th, 2011 | 07:55 PM
made in the usa's Avatar
They always get replaced here in ohio they rott away.
Old April 25th, 2011 | 09:51 PM
Boldsmobile's Avatar
Did mine too and found a kit somewhere that had replacement rivets - instead of bolts to replace the rivets.
Old April 26th, 2011 | 11:35 AM
STLCRZY's Avatar
I think this is what i need...and you install 66luvr....correct?
http://www.kts.de/shop2/default.asp?...33&onload=true
regards from Germany
Old April 26th, 2011 | 11:37 AM
STLCRZY's Avatar
Old April 26th, 2011 | 12:08 PM
66luvr's Avatar
Yep, thats it.
I didn't notice you were in Germany. I went to the link you posted to see what you found, it was all in German, I couldn't read a thing!! But of course the picture tells the whole story, pictures have no language barrier,,,thankfully.
I have replaced a few of those. A new rubber ring will often "tighten up" the steering a lot.
The long pins/rivets are a fail safe thing, they are long enough to allow some steering if the rubber comes completely loose, maybe sloppy steering, but you still have enough control to get stopped without wrecking.
Good Luck, Mike
Good luck
Old April 26th, 2011 | 12:21 PM
STLCRZY's Avatar
okay great Mike....
i ordered it today and hope i can stretch your nerves again if i need help with the assemble.
nice rims...
Denis
71 Cutlass
March 16th, 2013 08:28 PM
March 8th, 2013 07:26 AM
bobfo1
Suspension & Handling
October 3rd, 2012 04:00 PM
MDchanic
May 22nd, 2011 10:21 AM
J-(Chicago)
August 22nd, 2009 10:25 PM
