Front end steering play
Old February 8th, 2017, 06:25 PM
Runner
Joffroi's Avatar
I original started a thread in the brake/wheel section because I jumped the gun and just thought I had a wheel bearing issue. After the advice of many, I quickly found how it was very doubtful to be the bearing. I learned a lot about that process and since my brake rotor was pretty worn, went ahead and just replaced the rotor and bearings.
I wanted to start a new thread to have a clean slate on the next steps I had to take for my Oldsmobile. I still have wheel wobble and when I drive the car, especially on more lumpy roads, it is a little more difficult to control. I tried using a small pry bar at the components to find the play, but couldn't seem to get much information (maybe did this wrong?). From previous videos I've posted, I got a lot of recommendations about the center link needing replacement along with the idle arms.
I took another video of my car slightly jacked on the drivers side suspension and my wife jamming to the AM station and turning the wheel back and forth to publish more information about what is going on with my car. Sorry for the poor light and shakiness. Below are the links
I'd still like to try to tackle this on my own if its not to far fetched for an amateur car hobbyist / mechanic. ?As of now, my parts list is:
1) Center Line -
Amazon Amazon
2) Idle Arm -
Amazon Amazon
Guide I found I figured would be close to what I had to do:
I'm still definitely open to advice and suggestion.
Joffroi is offline
Old February 8th, 2017, 07:08 PM
I definitely see the pitman arm-to-centerlink connection looking very bad (which is to say that the centerlink needs replacing), and I think I see the Left inner tie rod end looking a bit loose.
It's really hard to say much about the others.
I hate to say this, but if the steering were oscillated with a period of about a quarter to half a second, instead of the roughly 2 seconds you were doing, it would be much easier for you and us to see.
Also, you've got to hold the camera dead steady on each joint for at least a few cycles - it's very hard to see occasional relative movement while the camera is moving as well.
Finally, you didn't seem to be feeling the joints - you should do that because it is a good way to sense slight relative movement that's hard to see.
MDchanic is offline
Old February 8th, 2017, 08:09 PM
same but different
don71's Avatar
I'll echo similar thoughts.
Too much excess movement in the center link where the pitman arm connects.
Same for idler arm, just too much movement.
I can't say on the tie rods, just couldn't tell.
don71 is online now
Old February 8th, 2017, 08:33 PM
Lifting one wheel puts the steering in a bit of a bind and masks the loose parts. From your other post we clearly can see that the center link, the idler arm, and the inner tie rods had play in the joints. Since your probably going to keep this one a while, I would just replace all of it, tie rods are not expensive. You also need to check your ball joints and control arm bushings. When you replace the tie rods, take them off as a unit and measure center to center. Then assemble the new ones the same length. This way the car is drivable and you can get the car to an alignment shop without wearing out your tires.
Replacing these parts is not hard, just time consuming.
oldcutlass is online now
Old February 8th, 2017, 09:08 PM
For doing the job, you can rent a tie rod separator tool from your local auto parts store. This really makes the job a lot easier.
This one also does the job:
Fun71 is offline
Old February 9th, 2017, 04:52 AM
Or learn to use one of these:
Old February 9th, 2017, 08:14 AM
Hookers under Hood
76olds's Avatar
I have to agree with Eric, I would replace all the components. However if your on a budget I would change the centre link along with the idler arm to begin. The pickle fork that Kenneth posted will help with the BFH that Eric posted. Other than that as others mentioned its very difficult to pinpoint the exact components needing replacement. Pull up and down on the tie rods will give you some kind of indication on the play.
Depending on the climate your live in, you can shoot a few shots of grease in each component. Wipe of the black grease off of each boot and around the area prior to shooting the grease in.
If you see the old grease come out a little lite brownish , this means ther is condensation inside the component which = play.
76olds is offline
Old February 11th, 2017, 12:09 PM
Runner
Joffroi's Avatar
I have bits and pieces of the CMS for 72 on PDF, but unfortunately not the suspension section. Is there a trick to getting off the two bolts holding on the idler arm? I see how they are connected to the frame, but the only access point to the bolts are through the 3 holes on the outside. Is having a socket extension to hold the inner frame bolts while I turn the outer idler arm bolts the correct way? I'm fairly nimble and this is going to be a challenge.
Joffroi is offline
Old February 11th, 2017, 12:11 PM
I believe those two bolts are splined and don't turn when you remove the nuts.
MDchanic is offline
Old February 11th, 2017, 03:54 PM
You believe incorrectly. The bolts are not splined and you do need a socket and extension through the clearance holes in the frame. Have one of those telescoping magnets handy, because at least one of the bolts and possibly the socket will fall into the frame at least once.
The only bolts on the chassis that are splined into place are the ones holding the upper control arm shaft, to facilitate front end alignments.
joe_padavano is online now
Old February 11th, 2017, 03:59 PM
By the way, a couple of lessons-learned on those idler arm bolts. When removing them, use a deep socket. When you get the nut off, push the bolt as far into the deep socket as possible. Use a rod or something similar to continue pushing the bolt/socket/extension until the bolt is clear of the idler arm. This prevents friction from pulling the bolt out of the socket as you extract the socket from the frame. Fail to do this and the bolt WILL fall into the frame rail. Do NOT ask me how I know this...
When reassembling, use a normal socket and wedge the bolt head into the socket. I use a piece of a plastic grocery bag as a shim around the bolt head before pushing it into the socket. This provides just enough friction to hold the bolt while still allowing you to extract the socket after tightening the nut.
But, but... "Freedom of Religion."
MDchanic is offline
Old February 11th, 2017, 04:04 PM
To avoid starting a political rant, I'll just stifle my clever retort...
Old February 11th, 2017, 04:07 PM
Hookers under Hood
76olds's Avatar
Or because people don't have plastic grocery bags on hand since we now supply our own green bags, you could spread some of that old black bearing grease inside the socket and on the wrench to hold the nut in place and the suction of the grease will make it a little easier.
76olds is offline
Old February 11th, 2017, 04:33 PM
mrolds69's Avatar
Ok... right, they are not splined, the nuts should be lock nuts. There are special thick washers on the bolt inside the frame. They are like steering box washers. THOSE (and the bolts) are what you have to worry about falling in the frame. Like Joe said, you need an extension. Pushing them through and the bag are good advice. Personally, I would use a regular socket, because I'd be more worried about the special washers rolling in the frame, than the bolt. Using a regular socket the bolt could only go in the socket so far and would hold the washer on.
mrolds69 is offline
Old February 11th, 2017, 04:41 PM
I stuff some dumb dumb into the socket so the bolt sticks to it, then they don't fall into the frame.
Old February 11th, 2017, 05:22 PM
I find a torn off corner of paper towel works well in a pinch, too.
Also, a bit of electrical tape.
MDchanic is offline
Old February 14th, 2017, 03:46 PM
Runner
Joffroi's Avatar
I haven't had much time to work on the car due to unforeseen events, but wanted to at least provide an update. I ordered and received a new center link and idler arm. I had a little time to at least try to get all the castlenuts and idler arm bolts looks and ready for replacement. Most didn't take much time but the top idler arm nut is being stubborn. Gave it a couple shots of WD40. I'll definitely jam something in the frame to catch idler arm bolts when I get to that. Hopefully this weekend.
Joffroi is offline
Old February 14th, 2017, 04:07 PM
Knock the tie rod ends out of the center link first, then knock the center link connection at the pitman arm, and then unbolt the idler from the frame. If you don't do it in this order you will have great pain in getting it all apart.
Old February 16th, 2017, 07:23 AM
dalilama's Avatar
This is good advice Eric. I'm going through a full front-end replacement at the moment myself and I figured out this sequence as well. My idler arm is in OK shape but I figure MAW replace it as long as I needed to remove it to get everything out. Good luck Joffroi!
dalilama is offline
Old February 20th, 2017, 08:41 AM
Runner
Joffroi's Avatar
I wish I had a more exciting update, but apparently my strength is causing much embarrassment (or I'm just dumb). I can't get the tie rods separated from the center link. I've beat on it and can't seem to make it budge at all. Went to the store and got a pickle fork to jam in between the center link and tie rod and still can't seem to make any progress. I have an uncle in the area that is experienced with this I'm going to try to see if he can come one day (he has built a few hot rods). Although that $300ish quote to replace all that at a garage is starting to sound decent to me, he says we should definitely be able to tackle this.
Joffroi is offline
Old February 20th, 2017, 08:46 AM
Here's a hint. Be sure the steering is all the way to the stop and hammer parallel to the center link. Any motion or flexibility when hammering absorbs the blows of the hammer without forcing the pickle fork in. Alternately, get one of these. I've been using this lately and it's MUCH easier.
Old February 20th, 2017, 09:54 AM
Here is a tutorial on using a hammer.
Old February 21st, 2017, 04:42 PM
Alex72cutty's Avatar
What size centerlink bar are you going with?
Alex72cutty is offline
Old February 21st, 2017, 04:56 PM
Runner
Joffroi's Avatar
I will be going with this.
Amazon Amazon
Joffroi is offline
Old February 23rd, 2017, 11:59 AM
dalilama's Avatar
Joffroi,
I also went with the Moog center link. It's on my bench now and it comparing it to what I removed it's way tighter at the end links. So were all the tie rod ends. If you have never replaced these I'm willing to bet they are loose as well and if it's in your budget for another $120 or so you could replace replace them with Moog parts.
Just sayin'
dalilama is offline
Old February 24th, 2017, 11:20 AM
Originally Posted by dalilama
Joffroi,
Just sayin'
What was the part number for the Moog centerlink you used?
Old February 24th, 2017, 12:54 PM
72 Olds CS
RetroRanger's Avatar
alex the PN is right in the joffrois link
Moog DS749 Center Link
RetroRanger is offline
Old February 24th, 2017, 06:21 PM
dalilama's Avatar
Yep - that's the one.
dalilama is offline
Old February 25th, 2017, 02:50 AM
Got it
Old April 12th, 2017, 11:04 AM
  #31
Runner
Joffroi's Avatar
I finally had time to sync with a friend of mine that had a little more experienced and offered to help out. We were able to replace the center link and idler arm. It took us about 2 hours and the following took is what really helped us get the center link free. After that is was just elbow grease getting the rest of the bolts off. The new pieces fit great. Took it for a test look around the block and it drove must better. I image after an alignment it will improve even more. Thanks for all the suggestions on diagnosing the problem.
Joffroi is offline
Old April 12th, 2017, 02:06 PM
  #32
same but different
don71's Avatar
Glad you finally got it done. I know I'll keep that tool in mind...next time around.
Thanks for updating your progress.
don71 is online now
Old May 10th, 2017, 06:52 PM
  #33
thirstybob's Avatar
Great info! Subscribed
thirstybob is offline
Old May 10th, 2017, 06:55 PM
  #34
Well done
Boiler_81
June 27th, 2016 08:11 AM
Jimoldsfan
September 25th, 2013 01:38 PM
AboutClassics
July 31st, 2011 01:14 PM
defiant1
January 26th, 2011 03:54 AM
tim72
May 23rd, 2010 08:24 AM
Quick Reply: Front end steering play
