Front end clunking noise............
Old May 28, 2022 | 03:35 PM
W-27's Avatar
My 68 442 as a clunking noise in both reverse and drive. I just replaced the upper ball ,joints and all the shims. I tightend the motor mounts (the passenger side one was really loose and this as lowered the clunking noise) the wheel log nuts were checked and are at factory specs. I also recently replaced both inner and outer tie rods ends. As anyone had a simular issue? Any help is appreciated
Old May 28, 2022 | 03:39 PM
Are you certain the noise is in the front? Check the driveshaft u-joints.
Old May 28, 2022 | 04:03 PM
W-27's Avatar
Good idea. I will check them as well.
Minnesotajeff
Aug 10, 2018 03:04 PM
Northern Custom Cruiser
Suspension & Handling
78
Sep 1, 2017 10:05 AM
Napoleon1991
Aug 18, 2013 07:40 AM
mv213
Aug 11, 2013 03:15 PM
meads
May 12, 2012 02:13 PM
