Can someone please explain this spring spacer?
Old April 11th, 2012 | 05:16 PM
hvysupreme's Avatar
Anyone ever see these before? Apparently they are some kind of aluminum spacer. I'm in the process of rebuilding my front suspension and when I removed the front springs, these were discovered in the lower A arms. Does this mean that these current springs that I have are aftermarket or lowering springs? They measure 16"...not sure what they should be. My car is a 350 with air. Any info would help so I know whether or not new springs need to be ordered. Thanks.
Brian
Old April 11th, 2012 | 05:18 PM
Oldsmaniac's Avatar
They are used for more lift. They are also used for worn sagging springs to give stock height back. With new springs you wont have to use them unless you want the front to sit higher.
Old April 11th, 2012 | 05:47 PM
hvysupreme's Avatar
Thanks for the reply. I assume that my local spring shop can check if the springs are sagging? Perhaps I can just eliminate these if the springs are good. The car does seem to sit a bit high but wasn't sure if that's the standard car height or what.
gws226
May 20th, 2024 09:46 AM
oldrelics
June 26th, 2014 06:19 PM
bobb
February 3rd, 2011 09:24 PM
jaunty75
October 16th, 2010 02:22 PM
jeffs 89 cutlass salon
November 5th, 2007 06:48 PM
Quick Reply: Can someone please explain this spring spacer?
