Ball joint issues
As noted, the ball joint stud is a tapered wedge locking fit in the spindle. Once the nut is properly torqued, the stud cannot turn in the spindle and thus the nut cannot back out. The only way for the nut to loosen is if the stud is turning in the spindle, which means that the taper is not seated properly. This is usually caused by incorrect torquing of the nut initially or a worn or damaged tapered seat in the spindle, preventing the stud from seating. The latter is more likely. The only other option is an incorrect ball joint or one with an incorrectly machined taper angle on the stud. All of these are dangerous to drive with.
